Results 1 to 10 of 13
Thread: Rear storage
    Aug 2013
    Howrah, Tas
    Rear storage
    How's anyone put in titan draws or made your own. Can you please put some pictures of your draws.
    Thanks landie56
    RR L322 owner
    Jason
    Range rover l322 2002 TD6
    Nov 2005
    Maudsland, QLD
    Quote Originally Posted by landie56 View Post
    Thanks landie56
    RR L322 owner
    I’d also be keen to see this as I also have been contemplating rear draws. Had Ron’s draws in my P38 but sold them with the car...should have kept them for the L322
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    THe problem with rear drawers how do you access your spare tyre without removing the drawers every time?
    Nov 2005
    Maudsland, QLD
    I would have the spare mounted on the roof cage if I was going on a trip. Would love a swing away tyre carrier
    Quote Originally Posted by Steinzy View Post
    Hey! I wanted them back!
    I have these Chuckwagon drawers in mine (they have been fitted in a Disco 1, a Defender, my P38A, and now the L322). They only go in for trips away. The spare wheel goes on the roof rack. My fridge is strapped in behind the front left seat. The rear 2/3rd seat is just folded up. You can see it in the 3rd photo.
    The drawers are bolted to Unistrut rails which are, in turn, bolted to the positions where the tie-down rings are normally fitted.
    I have two AGM Deep Cycle batteries fitted under the floor on the RHS in the well under the fuse panel.
    In the P38A (the narrower shelf was from when it was in a 110):
    Nov 2005
    Maudsland, QLD
    Great work Ron
    I take the boxes and the drawer out of the frame and can lift it in. It slides easily into position on the Unistrut and just needs a little wriggling to line up the bolts. I leave the floor out of the boot and have a filler piece at the very rear. It lifts out to give access to very large storage compartment made available when the spare wheel is removed. If needs be, I can remove the drawer or the lower plastic crate to get even easier access.
    Almost ready to go. The tyre is strapped on with a Y-strap.
    Aug 2013
    Howrah, Tas
    Like the simple way. K.i.s principal.
    Jason
    Jan 2010
    Cashmere, QLD
    I have put the Prado Titan Draws in to my D3 using turnbuckles to secure them to the existing tiedown points. I did need to rivet loop brackets to the sides of the draws but these are holding up fine. I can send pickture if required but is quite easy. You may need a plyboard under the draws to stop them rubbing on tailgate when open.
    May 2016
    Thanks landie56
    RR L322 owner
    Have a look at these plans for custom drawers for a D4 to get some ideas and perhaps modify them to suit your Range Rover. I used the ideas to build a custom set for my D4 with storage for 2 directors chairs, picnic table, compressor, tool box, maxx trax, shovel, fishing rod, plus plus. Also used the idea outlined to be able to lower the spare wheel without removing anything.
    Build your own Drawer unit.pdf - File Shared from Box.net
    Good luck
    Jaybee
