Results 1 to 10 of 13
Thread: Body off RRStdv8
    mustang2 Guest
    Body off RRStdv8
    G'day Everyone;
    Has anyone had the body off their RRS tdv8. either by themselves or at a professional workshop.
    If so how long did it take or how much labour hours were you charged.
    Can anyone recommend a workshop (east coast to SA) to do it.
    I have at least 1 blown head gasket or worse.
    Cheers.
    Brisbane, Queensland
    Body off RRStdv8
    D3/4 and L320 are probably near identical in terms of body lift. I can't see it being too complicated. If nothing on here maybe invest in a Rav or LR manual.
    I haven't heard of a blown head gasket before on a tdv8.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Safety Bay
    I'd get a second opinion on the blown HG before I'd go any further. Pat
    Quote Originally Posted by mustang2 View Post
    G'day Everyone;
    See my thread here:
    Engine replacement RRS Supercharged
    It took about an hour to get the body off.
    That's pretty clever. Whose car was it Ron?
    REMLR # 137
    Sep 2010
    The Hills.
    152.79 MB
    See my thread here:
    I believe the book allows 8 hours R&R.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sorry, Peter, I don't know. It wasn't a customer of KLR, it came from another workshop.
    mustang2 Guest
    Quote Originally Posted by PAT303 View Post
    G'day
    Thanks for the input I appreciate it.
    I've had about 4 or 5 professional opinions including TRS
    The engine blows 4-6 liters of coolant out in 100km with the van on.
    Had it on a dyno as soon as it reaches 94C, under load, coolant literally explodes out the degas bottle cap.
    No Co2 in the coolant this threw me and others.
    No overheat until coolant is low, then straight to limp mode.
    Degas cap tested ok 16psi.
    Cooling system test shows slow leak with no external sign.
    No coolant leaks any other location including thermostat housing.
    Google searches reveal Ford Lion diesel engines react this way especially the 6ltr F truck when towing if a head gasket is blown due to MLS head gaskets.
    1 RRS tdv8 case recorded in South Africa exact same symptoms.
    Every test reveals no other cause?????????????
    If anyone can suggest a different conclusion I would welcome it.
    mustang2 Guest
    See my thread here:
    G'day Ron;
    So who did the work?
    I've been quoted 30 hours on/off
    Thanks.
    I had the same with my P38A which did confuse us.
    Thanks.
    KLR Automotive now at South Windosr.
    You could also ask Davis Performance Landys.
    Quote Originally Posted by johntins View Post
    If I recall correctly, it took about 2 hours to refit the body. I got to the workshop to help and it was already on just needing the connections (brakes, electrical, etc.) to be done.
