Results 1 to 10 of 11
Thread: Cutting and joining a USB power cable
    Apr 2012
    Orange, NSW
    Hi
    I'm installing a strike phone cradle into my D2a and need to feed the USB charge cable through a cable gland, problem is it won't fit. Is there any issue with cutting and joining a USB power cable? Any tips or tricks to be aware of?
    Muppet
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Kallangur, Brisbane
    You can buy split glands somewhere....
    + 2016 D4 TDV6
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Disco Muppet View Post
    Hi
    Muppet
    It's pretty straightforward. On thing I prefer is to cut each wire at a slightly different length, so the joins are not next to each other, if you see what I mean, but it isn't vital. Careful insulation is though. There are only four wires. You got a small soldering iron?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Milton477 View Post
    Jaycar, if there's one nearby.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Apr 2012
    Orange, NSW
    I have a gas one yes. Are there still 4 if there's no data component? Anyway I can make it able to be separated easily? (Thinking male and female spade terminals or such)
    Apr 2012
    Orange, NSW
    Gland isn't the problem, it's the hole it goes into.
    Sep 2010
    The Hills.
    152.79 MB
    You may find them to be too fine for that.
    There re will be four. Black is earth, red is 5V green is data + and grey or white is data-.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Free Again Thanks Dan
    USB Connector Pinouts
    You can buy male and female USB blanks on ebay for a couple of dollars and yes it is doable
    And if no data you only need the 2 for power and earth
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by johntins View Post
    Try joining the red and black and see if it works. If it's only for power supply it should.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Back down the hill.
    No need to thank me, I'm just happy to be a help.
