Results 1 to 10 of 22
Thread: 2003 disco 2 V8 HSE cranks , wont run, help.
    cch Guest
    Gday All, I have an 03 V8 hSE disco 2 and Got the disco engine bay wet and then died on me , was running at the time it got wet, I have checked the fuel cutoff switch and changed(even used bypass to check), fuel pump runs and has been checked,have spark at all cylinder,can get to run with spray start into inlet but wont run like injectors are not working, I have even changed the crank angle sensor also, idle air cntl vlv works aswell, anyone got any ideas ,its driving me mad,cheers.
    Mar 2013
    Quote Originally Posted by cch View Post
    Its always worth finding someone with a nanocom or a scanning tool, it can save you hundreds when trying to resolve a single issue. However, since theres quite a lot of sensors that can become faulty, and still let the car turn over and run, your problem is narrowed down to a little.
    check to see if you have destroyed the fuse number 1 in the engine compartment fuesbox. This fuse supplys all 8 injectors with +ve supply. If you have blown that, it will not fire the injectors.
    cch Guest
    thanks for advise
    Hi, Yes I have a scan tool but shows nil codes due batt . went flat and all codes lost, I will check the fuse you suggested , cheers
    cch Guest
    -2003-disco-2-v8-hse-cranks-wont-run
    Hi, Yeah changed the fuse still no joy , checked all fuses/ relays ok,any thoughts , might have to get auto elec. to come visit for loose wire/short in system unless anyone has further to add, cheers.
    Apr 2015
    Hervey Bay
    I had the same thing on my old D2 V8. What worked for me is unpluging all the conections on the ECU and plugging them back in. She started straight up.
    Don't know why I had no fault codes either and changed the crank angle sensor as well, but it worked for me.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    cch Guest
    Hi , thanks for that will give that a try , anything at this stage, I also checked the relays etc.. today again and all good, one point though do you think I would lose the ecm settings, did you disconnect one at a time or all at once,cheers
    Crafers West South Australia
    The brown/orange stripe wiring that feeds power to the injectors also feeds various other small electrical parts around the top of the engine. Find that colour wire and test it for power with the ignition on. All the brown/orange stripe wires join in a "clinch" in the main harness at the back of the engine. Cutting the right wires for LPG conversions is paramount so I'm used to getting at those wires.
    Apr 2015
    Hervey Bay
    I don't think that unplugging the ECU will cause any issues. I had mine unpluged for weeks when I did an engine rebuilt with no adverse effects.
    I just unplugged them all to look at the connectors, mainly cause I tried everything else to get it running. Thought they may of had a bit of corosion on the pins or plugs, but they all looked fine. Plugged them back in and bam, started straight away. Had me scratching my head and saying WTF, but it started and I was happy.
    91 Kawasaki GPZ900R
    cch Guest
    Hi Gents, tried & unplugged all ecu connectors and reconnected, still no joy, I will try finding pwr to the wire you suggested when batt is recharged, thanks for all your help gents I;m really appreciating it all,cheers.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    if you have a nanocom or simlar, maybe try the learn security function, long shot, but couldn't hurt to try, it might just start .
    cheers,
