Results 1 to 10 of 23
Thread: Steering Relay shaft - any good ?
    Jul 2016
    Hi All, I have cleaned up steering relay shaft, but it's quite pitted from rust, so I am looking for the option of the Landrover brains trust to tell me if it's usable, or whether I should bin it and buy a new one, pics are here :
    The surfaces that bear on the fibre bushes are probably not an issue - they will probably wear the bushes a little faster, but this should not be an issue. The surfaces the seals bear on is another issue - you won't get them to seal without fitting sleeves on it. I would be inclined to seek a replacement shaft, or perhaps look for another relay, even a second hand one that may have the shaft in better shape. Someone on the forum may be able to help - perhaps a "wanted" ad might get something.
    Narre Warren South
    I machined the sealing surface and it worked out OK. By reducing the diameter slightly the seal isn't quite as tight so it depends on the depth of pitting. Might be able to speedi-sleeve it.
    Get seals from a bearing supplier rather than a LR parts supplier. Tend to be better quality.
    DSCN2397 by Colin Radley, on Flickr
    Beware of pattern/aftermarket relays or shafts. There have been stories of the shafts twisting & breaking.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Apr 2014
    Blair Athol, Adelaide South Aust.
    I'd get another shaft and go from there...it's not like there aren't any around or that they are rare, just a pain to remove from a chassis mostly.
    Cheers Rod
    Quote Originally Posted by 67hardtop View Post
    Cheers Rod
    There are probably people who have a chassis or part thereof with an immovably fixed relay, who could be persuaded to part with the shaft - which is a lot easier to remove than the whole relay.
    Jul 2016
    Thanks for the input guys, I guess I can try milling it down a bit where the seals would mate, but I suspect I will be looking for a replacement shaft.
    I haven't seen anyone selling genuine Landrover shafts, only the third party ones.
    Are the third party ones really that bad ? i.e. roverparts sell the shaft for $50.
    Narre Warren South
    Quote Originally Posted by JohnboyLandy View Post
    The problem is....with a steering component do you want to be 'testing' it or buying something fit-for-purpose.
    In another thread a member commented that they had a pattern shaft shear off and a LR supplier in the UK wouldn't sell them at one point (but I notice they now sell the Bearmach unit complete).
    As suggested, there must be some kicking around in someone's spare parts pile, hopefully not full of water.
    I parted out a vehicle a while back and scored a good one as a spare, just needed new seals & gaskets.
    Coli
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Oct 2014
    Northern NSW.Australia
    Cant see why a good degrease, JB weld or suitable epoxy sand back. Double lip seal. would be ok.
    Works for swivel ball.
    Ready to be shot down in flames with my comments
    whitehillbilly
    Jul 2016
    Does anyone know the part number for a double lip seal from Repco or Kelpro etc for the steering relay seals ?
    Jan 2008
    ACT
    which part of the country are you in?.....my relay was cactus on the outside and I got a unit from the Ho Hars I reconditioned but, have the internals of the old one in a box...the shaft was all OK from memory. Probably still got the special brackets I made to put that damb spring back in also:-) I'm in the ACT.
    col.
