Results 1 to 8 of 8
Thread: What tyre pressure do you run?
    Perth WA
    Hi All
    My weekend drive is a 1992 RRC with 31 X 10.5 X 15 AT tyres on turbine mags.
    Most driving is on black top 95% with some gravel driving.
    Most times I'm driving by myself ... vehicle has 2" lift, and assortment of tools which most Landy drivers would have on hand but nothing overboard.
    The 10.5 X 15 tyre gives I believe give the same dia as a 16 in tyre except for the obvious extra width
    Just wandering what tyre pressure I should be running or what people are running on similar size tyre or on their 16" rims.
    Currently I'm running 36 PSI ....
    Baggy
    Apr 2011
    Dungowan
    30/36 F/R when i had mine, on 10.5's. I do a lot of dirt roads tho.
    Two Rocks WA
    Ditto with what Rick says above, however if I am loaded up I might increase them all by 2 psi front and rear.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Perth WA
    Thanks Rick1970 and Bradtot,
    Noticed a bit of uneven wear on the front tyres and increased pressure to 36 psi all round.
    I've been a bit lazy recently and have not checked them as I normally would and they were low in the front.
    My usual tyre pressure does hover between 32 - 36 psi nice to see I'm on the money with what others are doing.
    I'll monitor them over the coming weeks she unfortunately is not my daily driver (company ute) and I barely cover
    6ks in a year.
    While I really should get my 81 2 door Rangie on the road I must say that I do enjoy this 92 classic.
    Its quieter, rides nicely on its current spring setup (previous owner has removed air suspension) and rather reliable
    which for a Rangie is not always spoken of in the same sentence especially with the additional electronics
    Baggy
    May 2017
    I have mine on the standard 16x7 three-spoke wheels and new Pirelli Scorpions ATRs.
    The tyre guys recommended 40psi which seemed high but I took their advice. I am finding the ride a bit rough so I may try airing down to 36 after having read this thread. Thanks!
    Perth WA
    Hi Classic88
    Your not the first to be told unusual tyre pressure and 40psi seems high.
    Pirelli Scorpions ATR are a nice tyre and I'd like to hear how you go with reduced tyre pressure and how they perform for you.
    Baggy
    WA
    I just got some new Bridgestone D697 tyres in 245/70 16 size and the tyre guys put them at 32psi, which is quite a bit lower than what I had in the old ones. However, the ride is fine and the tyres look like they should, so we'll see. I made a big mistake by not rotating the old set, which wore out oddly once a Truetrac was in at the front axle. The big problem with tyres is that once you've got the experience with a set to know what you should have done in the first place, it's too late!
    At any given point in time, somewhere in the world someone is working on a Land-Rover.
    May 2017
    They are nice and quiet and seem confidence-inspiring on both dry and wet tarmac. I haven't been off the blacktop at all to test that aspect of them. Certainly better for my purposes (knocking bout town) than the 15x8s with General Grabber AT2s which were on previously.
    I did a fair bit of research first and the Scorpions definitely seemed like the best price/performance compromise for road use. I got a good deal which included a fuel card promo from Pirelli and other than the surprising pressure advice the people I used were excellent. If anyone in Sydney area is after new boots, send me a PM and I'll let you know where I went.
    Only issues I am having is that they do rub on full lock but then I did go for the biggest I could on those wheels plus wheels are corroded inside and not holding air perfectly so they need topping up more frequently than they should.
    Quote Originally Posted by Baggy View Post
    Hi Classic88
    Baggy
