Results 1 to 3 of 3
Thread: Climate control/ventilation control problem Defender 130 2.2
    Jun 2007
    Margaret River
    Today something in the ventilation control system (that directs air at your face or feet) seized up and will not move from the second last setting
    I will remove the console panel for a look, when I get a chance, to see what the problem may be
    In the meantime is there a common cause for this to get jammed up?
    Jun 2007
    Margaret River
    Solved.
    Opened the hinged cover under the "glovebox" and was able to feel around for the vent direction actuator,
    By rocking the control dial and helping the actuator the control freed up and now works fine.
    Didnt need to remove the consol fascia
    VladTepes's Avatar
    Bracken Ridge, Qld
    Does yours make a difference as to which position it's in? That's novel....
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
