Thread: SRS Warning light.
    garp Guest
    SRS Warning light.
    Hi all, I'm, in Eden NSW. I have a nice p38 4.6 on gas. Trouble is I had the computer out from under the seat to get it reset and I think I might have dislodged the yellow SRS wire. It failed a rwc for the light being on, and a rear seat belt cover! (also a M/C but I've got that)
    Is there anyone close to me with a rovercom/nanocom? that can zero the fault?
    I'll put someone up for the weekend if they help me, I live in a great place and I'm not a nutter. You can look at my yt site for proof
    Amazing Air Suspension! - YouTube
    I already tried to disconnect/reconnect it, but I'll have another go...
    May 2003
    On The Road
    If its the same common SRS fault as the D2's ( and it probably is) you just need to unconnect-reconnect the yellow connector under the seat,,
    anyway,, its worth a go,,
    Douglas Park, NSW
    Come up to Sydney for the LR Expo this weekend, campsites available & there will be Nanocoms galore amongst the P38 crowd .
    Oct 2007
    Williamstown, Victoria
    Make sure you disconnect the battery first, then have a look under the drivers footwell panel, find the yellow wire, disconnect and re connect it a couple of times.
    That clears the SRS fault for me. On post 99 models there is also a connector under the drivers seat.
    Feb 2013
    Gosford, NSW, Australia
    Disconnect the battery and wait 20 minutes, as per RAVE
    Steve
