Results 1 to 8 of 8
Thread: 101 Throttle Cable
    101 Throttle Cable
    Just going through the joys of trying to replace the throttle cable in my 101. I did it about 9 years ago and had nightmares for a while after trying to sort the cable to the pedal. I think I gave up and did it when I had the booster and pedal box out.
    Any way my piggy little arthritic fingers are doing it tough and I still have not worked out how to undo nuts or remove split pins with a mirror and light.
    Looking at it I cannot see any reason to get a couple of longer cables made and make up a new throttle pedal an mount in the clear space to the right of the brake pedal.
    So has anyone made up a new accelerator pedal and bracket (or used one from another vehicle) so the cable runs to the right of the brake pedal rather than down between the clutch and brake pedal and behind the brake booster where it is impossible to get at.
    I cannot believe the designers went the way they did when there is free space just above the current pedal.
    Feb 2013
    Garry,
    Has the 9 year old cable failed or was it an old, used replacement?
    My 101 doesn't see much action these days, but the cable seems fine.
    Phil
    I guess none of you 101 owners have had to replace the accelerator cable - when you have to do it you will understand the issue.
    Apr 2011
    Wandong,Victoria,Australia
    Hi Garry,
    I think that Sitec had to replace one - and have a vague memory that it is a pig of a job.
    I've never had to do it - thank goodness.
    GG.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    They so have a bit of a history in breaking so i always carried a spare - again stupid Brit way of designing things - the pedal is part of the brake and clutch pedal arrangement where there is room to have a stand alone item next to the brake pedal and bolted direct to the nose cone. All the bits and pieces are up behind the brake booster and almost impossible to get to without removing the booster and master cylinder.
    Aug 2010
    Sunbury, VIC
    Yes, I've had my cable break and it is a PITA to do - When I put it back together I couldn't get the split pin in so left it out, only to have the main pin fall out a few months later while towing my van up a narrow winding road...
    I got the pin back in and got home, then spent some time getting it sorted properly.
    Jan 2008
    Nowra NSW
    After 10 years of owner ship I know my 101 is due for a new accelerator cable.
    It is starting to give out just near the carbies.
    I will be going though this learning/ swearing process soon.
    Quote Originally Posted by Homestar View Post
    It took me about 2 hours to get the split pin out - a real pain.
    Putting it back together I was going to use a small R clip but I haven't been able to find one small enough locally so I used a safety pin which went in less than 5 minutes. I cannot get the bolt tight that hold the cable in place on its mounting bracket.
    I do have a job to do next year that requires the master cylinders and brake booster out (replace with a D1 dual booster) so I might build a new pedal arrangement then.
    For now it works but I am not a happy chappy.
