Thread: House Air Con Question
    Mar 2012
    Armstrong Creek, Qld
    Should you run the home air con every so often like the vehicle systems?
    Steve
    Oct 2008
    Cloncurry NWQ
    Why would you turn it off?
    Oop's, just noticed you don't live in Doomadgee!
    Short answer yes.
    Jonesfam
    Mar 2012
    Quote Originally Posted by jonesfam View Post
    Short answer yes.
    Jonesfam
    Thanks. Only got it recently in stalled. Only 39° here at present.
    May 2012
    Wannanup WA
    4.70 MB
    Not really necessary. With a car air con. it has a mechanical seal on the compressor shaft. It will deteriate because of a lack of oil, and start to leak if left for too long with out being used. (varies with the type of compressor.)
    A domestic compressor is hermetically sealed inside the housing. The only place they will leak are faulty connections in the gas tubing, or other such damage. If it is going to leak running it now and then will not make any difference.
    Brisbane,some of the time.
    The only reason to run it would be to blow out any geckos,rats,snakes,and anything else that may be hiding in it.
    In fact,more importantly,every six months or so i would take the top off and spray lanolin around.Also spray around the electrical and pipework entry holes,and around the base of the unit.
    Vermin in domestic split systems cause more failures than anything else,damage to PCB's being the main issue.
    That is apart from installers that don't know WTF they are doing.
