Results 1 to 10 of 34
Thread: Now a head gasket
    South Yundreup,WA.
    Now a head gasket
    Well here we go again, looks like another head gasket. Started car up today an plume of white smoke. Coolant level down a bit. Further investigation Pro Vent catch can, goop (water & oil), same in rocker. To make it worse oil around the exhaust from turbo manifold so maybe a turbo issue as well.
    All in all a complete **** day.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Kingston, Tassie, OZ.
    Damn. Thats not good Craig. There is also the possibility of a crack in an exhaust or inlet port however that is actually a much worse scenario 😢😢
    South Yundreup,WA.
    yeah hoping it is not that. Any easy way to check there is not a crack?
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Head off I'm afraid anyway as there is an interface somewhere between the crankcase and cooling system. Could also be a bore porosity problem as the moisture in the crankcase can enter via the cylinder wall below the level of the piston, which will not cause any hydraulic lock.
    Jan 2017
    Geraldton WA
    I wouldn't overthink this as this can drive you Nuts, Just get the head off and go from there.
    Hopefully it is a simple case of a failed head gasket
    4.6m Quintrex boat
    Aug 2008
    Perth, WA
    37.36 MB
    I feel your pain Craig. Earlier this year doing a routine check in my D1, I found a thin layer of oil sitting on top of the coolant. Enter that sinking feeling.....
    Jan 2017
    Geraldton WA
    My D2a is in the workshop now with problems with the head gaskets.
    4.6m Quintrex boat
    South Yundreup,WA.
    Thanks Justin. Yeah head has too come off regardless, next break maybe.
    I would assume a crack would be pretty easy to see?
    Gasket may or may not show tell tale signs, that is an issue as not always clear.
    How would you determine a porous head??
    If a head what are the better options?
    I see Turner Engineering have them for around 1125 GBP ready to go.
    There gos the rest of my tax return if the case.
    The only aftermarket I can seem to find are AMC, with Island 4x4 so far the cheapest at $1000 GBP with valves ready to go. Turner Engineering 1125 GBP (app $1925 AUD). SMS Diesel Australia $3300 AUD.
    After some info on AMC heads if I have to go this path or other options if i need to. Waiting for a price from TRS.
    Likely I will source from the UK as prices here just ridiculous.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Aug 2008
    Perth, WA
    37.36 MB
    Craig, I went through a local Indie and got an AMC head. It should last longer than the original. Good luck!
    AMC are the better choice 100%. Yes the prices here are silly. I won't supply overseas purchased bits though as there is NO, read NO, chance of getting any warranty back up. I learnt that the hard way...
    Jc
