Results 1 to 10 of 32
Thread: Auxiliary battery.
    St Helena,Melbourne
    1.13 MB
    Auxiliary battery.
    Did a measure up of my 105ah supercharge battery and the vacant spot by the abs pump and it misses out by 3cm Auxiliary battery. , also tried the space near the coolant bottle but also just misses.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    If you are just looking at an aux battery - why are you looking at a Supercharge which is a compromise battery - part starter part deepcycle. Does both OK but not the greatest at either.
    Having said that I do have a Supercharge as the Aux in my 101 where it does run the fridge etc but also the ignition and 12v accessories but start is from the 24v battery bank. I also have a Supercharge as the starter in the RRS as it does meet starting specs and is best value for money but not expected to last as long as better starters that are twice the price (dont give twice the life).
    I believe if you arrange the overflow bottle etc - a full size battery will go in front of the starter but under the ABS box you will need something like a 50Ah Yellow Top - if you believe the talk the 50Ah Yellow Top works like like a 75Ah normal deep cycle. Not totally convinced.
    May 2009
    West Gippsland - Victoria
    That's all right. I'll swap you my brand new Century 55D23R MF (230X170X210) 60 ah for it
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    May 2009
    ........................................ is best value for money but not expected to last as long as better starters that are twice the price (dont give twice the life).
    .................................. 50Ah Yellow Top - if you believe the talk the 50Ah Yellow Top works like like a 75Ah normal deep cycle. Not totally convinced.
    Nothing wrong with SuperCharge batterys, I've had several over the years and they are my SLA battery of choice. As you say, excellent value for money and are as good as or better than their competition. I've found that the marine N70ZZ variant to be especially good in high vibration (corrugation) applications and definitely outlasts its competitors.
    Optima batterys are as good as they're made out to be, or better IMO. I've got 3 that have been carted all over the country in the Oka and have lasted 7 years and are still going strong. IMO the Optimas greatest strength is its vibration damage immunity and it's ability to store charge very quickly. A great benefit if traveling in 'short hops' as they can be fully charged a lot quicker than conventional lead acid batterys.
    Deano
    Ean Austral Guest
    I was under the impression the optima yellow top can be used as both start and deep cycle.
    Cheers Ean
    Queensland
    Hi Loanrangie, with the D3 battery compartment on the driver’s side, the only battery that fits without the need of any form of modification is the Optima D34 Yellowtop.
    I have heard that there may be an Odyssey that will as well, but I know nothing more than that.
    If you fit a battery tray on the passenger side, just in front of the cranking battery compartment, you can fit another Optima yellowtop D34 there as well.
    There are a number of other small batteries that can be fitted in the same spot in front of cranking battery but the size increase is so small it is just not worth going beyond the Optima D34 which is a 55Ah battery.
    As DeanoH posted, the Optima can be rapid charged and in a very short period of time compered to other batteries, and if you really wanted to you can fit two Optimus under the bonnet of a D3 and “some” D4s.
    St Helena,Melbourne
    1.13 MB
    I already have supercharge battery which is why I measured to see if it fits, would like a 75/85ah at least just a shame my battery won't fit as it's a cost I didn't need .
    Also my last sc battery lasted 7 1/2 years as a main and I can buy 2 for the price of 1 optima.
    1974 VW Kombi bus
    Queensland
    While not the ideal solution, you could mount the auxiliary battery in the rear cargo area.
    Dec 2011
    Adelaide
    142.79 MB
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    When I had my J**p Wrangler diesel, it came with the D34 Yellow top as standard battery. Mine lasted 3 1/2 years.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Dec 2011
    Adelaide
    142.79 MB
    I've got my D34 mounted up front, as part of the Traxide kit, and I have an 80ah Thumper in the back which is kept charged via the Traxide wiring as well.
    REMLR 012
