Results 1 to 10 of 26
Thread: historic rego
    Jan 2009
    historic rego
    I tried to put my 2a LR with holden motor from full rego to historic rego and the RMS refused to do it said i needed engineers cert. has anyone had this problem
    Western Victoria
    When was the conversion done and who did it?
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yes, it will depend on if it as been previously registered with that engine - and more importantly if it's had the current engine number on the system. While it is currently on full rego, they may not have any details of that engine as it may have been done years ago and the rego authority never notified.
    If it has been, then you may have just come up against someone who has no idea - there's plenty of them out there.
    Check your rego papers to see I feel the engine number matches.
    Cessnock NSW
    Also different states have differing rules, I'm not 100% certain but I think In NSW the vehicle has to std, good luck anyway cheers Dennis
    Jan 2009
    Quote Originally Posted by Dinty View Post
    full rego has the holden engine number. been regoed with holen for a few years
    Western Victoria
    Quote Originally Posted by MACKA View Post
    Shouldn't need engineering, then.
    Dinty has a valid point. I know that is the case in SA.
    I know of a Series 2a with a holden motor on historic plates in NSW.
    Sounds like the RMS person needs some training.
    '51 Series 1 80"
    '12 Defender 90
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Larry View Post
    Could well be the case....
    Apr 2011
    Windsor NSW
    NSW-easy if
    Hi,
    my S1 ute had a 175 Holden and I put it onto Historic plates with no issues at all as it had been previously regoed on full plates with the Holden motor so it was already in the system--if so it should be no issue and no need for eng approval. There are hundreds of Holden engined LR's in every state.
    Alan
    Douglas Park, NSW
    It might not be on H plates soon though if the CMC find out. They're supposedly clamping down on 'period modifications' & asking that they go onto the CVS (modified scheme).
