Results 1 to 10 of 16
Thread: De canting Gas
    De canting Gas
    With the advent of swap and go it is getting harder to fill my small gas bottles so I thought of decanting from my large lpg bottle.
    I can connect both bottles together with the regulator removed but do I have to do anything special to get the gas out of the big tank to the smaller one. Someone has said the the bottle to be filled has to be lower than the one form which the gas is coming.
    Any other tricks
    thanks
    South Yundreup,WA.
    The gas level has to be higher than the one being filled or it will not flow as liquid. If you are decanting from a home cylinder if the cylinder is nearly empty it will need to be inverted.
    Most towns should still have a fill station. Over here and in SA it is usually Kleenheat Gas. You should have Origin (Boral) or something similar.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Thanks for the info
    Gazzz
    Toowoomba QLD.
    Re: De canting Gas
    Any other tricks
    thanks
    8O 8O 8O 8O 8O 8O 8O 8O 8O
    www.bcga.co.uk/preview/pdfs/TIS13.pdf
    Don't do it!
    Trev.
    Jul 2003
    It is simple physics:
    Pressures equalise.
    You may fill the empty smaller volume tank depending on the volume of gas in the big one but you will never empty the big one
    When you fill a bottle at the servo there is no regulator.
    Mahn England
    Ex 300Tdi Disco:
    SYDNEY -in the shire.....
    <span style="color:blue">there is a regulator and a safety switch on the top of the the big bottles....
    and the bottle being filled has a pressure release screw open to allow it to fill......
    hence giving it a lower pressure than the bottle it is being filled from......</span>
    If I am filling from a 9kg bottle - surely the smaller bottle cannot be over presurised because the smaller bottle would normally be filled to the same pressure if filled at the garage.
    Does the garage fill different sized bottles to different pressures?
    Gazz
    Brissy! No flannos here!
    Yes,
    I am keen to figure this out at well.
    At the moment I rely on the spotty, 'english is a second language', teenager at the local servo to do mine.
    It doesn't look hard.
    Ralph
    South Yundreup,WA.
    Remember the big tanks used for filling also incorporate a pump, they do not fill just on a line. Father in law was a kleenheat gas manager for lots of years. To fill from one cylinder to another you need the correct hose. As said you will not be able to empty the donor cylinder completely using this method. It can get you out of trouble however. I hav also seenthe set up to decant lpg into a vehicle to get out of trouble.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Gazz
    <span style="color:blue">no....they would both have less pressure than the 9kg had at the start as
    the same amount of gas is now in a larger area...(two cylinders) and the one being filled will have been releasing pressure to allow the gas to flow into it.....</span>
