Hello and excellent report...
Sorry to sadden you though... those wheels aren’t load rated to the Disco.... you can’t run RRS wheels on a D4...
If you are going to run that size tyre the HydroBushes and sidewall flex will likely see them rubbing everywhere from your photos... so continue to observe....
And you will need an emergency EAS kit - otherwise when it drops you will be stuck hard.
