Results 1 to 10 of 40
Thread: Four stroke brush cutters , Sthil or Honda ??
    SW of Geelong
    I need a heavy duty brush cutter. I’d like to hear opinions on four stroke models, ideally from anyone who has directly compared and used the Sthil and Honda.
    I know there are differences between them , for example, you still have to mix the fuel and oil for the Sthil, but the Honda has a ‘sump’ which means the oil gets changed at services.
    I’ll be mainly using it for long grass which can’t be mowed, and also some scub and gorse. I prefer to use a blade rather than nylon string , hence the interest in a four stroke with a bit of torque.
    Cheers Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    May 2008
    Bundaberg Qld
    Quote Originally Posted by rijidij View Post
    Cheers Murray
    Jan 2017
    Geraldton WA
    If you have to premix the fuel for the sthil then it is a 2 stroke not a four stroke.
    The 4 strokes will last longer that the 2 strokes so looks like the Honda is the pick here.
    4.6m Quintrex boat
    Jul 2009
    Hobart
    Hi,
    I have a Stihl 4 stroke (yep Otto cycle with inlet and exhaust valves in the head) that has no sump and runs on 50/1 petrol/oil. It is one of the combi-tools and I have the pole saw, hedge trimmer, blower, and weed wacker heads.
    Very pleased with what it does and is quite economical on fuel.
    The only gripe I have with it is it can be hard to start, but a tin of Startyabastard and a quick spray starts it third pull. I suspect this is tuning, as it was easier to start before last service - I will have words with the dealer next service.
    I have noticed quite a few lawnies using them, and I doubt they have to use the spray to start, so I'm hopeful it will get fixed.
    May 2008
    Bundaberg Qld
    Quote Originally Posted by austastar View Post
    Hi,
    I have a Stihl 4 stroke (yep Otto cycle with inlet and exhaust valves in the head) that has no sump and runs on 50:1 petrolil. It is one of the combi-tools and I have the pole saw, hedge trimmer, blower, and weed wacker heads.
    How is the bottom end lubricated ?
    Jul 2009
    Hobart
    Hi, the oil mix is inducted over the crankshaft/big end.
    Shindaiwa Hybrid 4 Engine Technology Animation - YouTube
    Based on the Shidaiwa motor.
    May 2008
    Bundaberg Qld
    Just googled the Stihl "4mix" engine. Bloody amazing.
    Feb 2005
    Don't discount shidaiwa
    It been a while since I used a straight shaft Honda, we used it to do maintenance under macadamia trees.......It worked all day for days on end at full noise.
    I have a honda bent shaft for home these days....
    I'm sure the cordless brigade will he along with there tips on which is best.
    Crafers West South Australia
    I have a generic brush cutter powered by a Honda GX35 4 stroke engine. Always starts first time, never stalls, economical, well balanced, absolutely brilliant piece of kit. I'll be fuelling mine up shortly and attacking the front yard.
    Marty90 Guest
    When I was a lawny I had stihl 2 stroke everything. Brushcutters, blowers,hedgetrimmers,back/pack blowers pole trimmers. It's true they need tuning initially to start easily but any competent dealer/mechanic can fix it. Loved em and worked them hard everyday. Don't need to service them or check oil level. Honda's are great gear but for long periods of use I found them very heavy.
