Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: Anyone with a Chinese led headlight ?
    Aug 2014
    Switzerland
    I'm seeing many led headlights on Albaba and you can get a pair for less than 100$.
    I was wondering if anyway had the guts to buy a set of these and... whether they are at least better than the stock headlights.
    SW of Geelong
    I’ve tested a few Chinese LED headlights, about 5 different ones from different suppliers.
    To cut a long story short, these are the most popular ones with Land Rover owners because, unlike the majority of Chinese lights, they are ADR compliant and have a good high beam.
    Cheers Murray
    Landrover DEFENDER Pair 7'' *LEGAL* 105W Round LED Head lights DRL+TURN | eBay
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Nov 2011
    I purchased some 40w ones a few years ago and they are an improvement over the standard lights.
    You will get better output by upgrading the wiring and installing relays switched by the original switch if you have not already done so. This will also save you burning out you light switch at some point.
    If i was buying them again now the ones already linked would be what i would be buying.
    Richard
    _____________________
    1985 V8 County 110
    1994 TDI Discovery 1
    2000 TD5 Discovery 2
    2010 TDCI Defender 110
    Land Rover Owners Club of Brisbane
    Jan 2012
    Surf Coast
    I've got the ones that Murray has linked to (had an eBay voucher thing that needed using so they were a bit of an impulse buy, the day before the voucher ran out!) but I have to say they're pretty damn good.
    There's lots of discussion on ye t'internet (and lots on here too) about the colour of LED headlights, some love 'em others can't stand 'em, and it is the first time I've ever used them and the blue/white light took a bit of getting used to after the yellowy halogens but they're growing on me.
    And the side lights/blinker lights is a kinda cool bit of bling 😀.
    Never tried the replacement LED bulbs, so can't comment on those.
    Another thing to mention is if you're after a headlight improvement is to consider the wiring upgrade from traxide (drivesafe on here).
    Dan
    '14 Def 110
    '75 Lightweight
    '98 300Tdi Disco (gone)
    '80 2Dr Rangie Classic (gone)
    Jan 2017
    Geraldton WA
    Compared to the LED lights the standard globes/lights are pretty much just "Mood" lighting
    4.6m Quintrex boat
    Dec 2014
    Branxton, NSW, Australia
    I bought some as well, but I have to say I am deeply disappointed in the low beam. The high beam is good though. I upgraded to relays for the wiring at the same time so they are getting full voltage. I wonder what you are doing differently to get a better result? Maybe my expectations were too high and I expected a big improvement for my hard earned money? The low beam just doesn't have the penetration it needs, it's bright a few metres from the Landy but fades off into nothing where I NEED to see. Even the high beam sits too low for me, which suggests I need to aim them higher but I think if i go higher it will be in driver's eyes. Anyway, disappointed I wasted my money, should have just upgraded relays and put good bulbs in.
    Current - Silver 2007 SE D3
    2005 Defender 110 Wagon TD5 - Gone :(
    Jan 2012
    Surf Coast
    Maybe I just have lower expectations, I dunno!
    I agree about them seeming to be a bit low, though. I swear I fitted them and lined them up properly, but they still seemed to point too low down. I have adjusted mine up and so far no angry full-beam flashes from blinded oncoming traffic!
    Dan
    '14 Def 110
    '75 Lightweight
    Oct 2017
    AU
    I have been using the Chinese copies for four years now. All good. The low beam is wide and bright enough for city driving
    Up the high country, I discovered some condensation inside the lens..But I think that's just moisture trapped during assembly
    I also compare them with genuine speaker gen 2 LED headlights. I would say speakers are better but not three times better....
    Also don't think a headlight wiring upgrade is nessacery. My low beam draws about 2 amps
    May 2006
    Woolgoolga
    Quote Originally Posted by hpal View Post
    Well now that you have done the wiring upgrade, swap back to halogens with decent globes.
    Dec 2014
    I've blown my money on the LED's then, am I out of line to expect a good product for my money that does what the seller claims?
