Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: far out , i thought i would service the aircon today
    Oct 2017
    nowra
    I cant believe the P38 system takes 1250 +- 50 of r134a gas ,, thats so much , my disco 2 with twin air held the same ??
    far out its cold now ,,,,,
    Would anyone know what types of bulbs are in the aircon control pannel ??
    Cheers all
    Bob
    Jan 2012
    Bendigo
    I've had aircon blokes remark on that in the past.
    How did you service it yourself?
    Sent from my SM-G900I using AULRO mobile app
    Quote Originally Posted by vk2loz View Post
    Would anyone know what types of bulbs are in the aircon control panel?
    See LCD Backlight Repair
    Oct 2017
    nowra
    Cheers Ron Just what i was looking for .
    Thanks Ron , I knew you could help
    Bob
    I did write a lot of that page.
    Oct 2007
    Williamstown, Victoria
    Yep, I had mine regased last weekend after replacing a leaky hose.
    The air con guy commented that it took a lot of gas, much more than most cars.
    He said that is as much as a truck air conditioner takes!
    Like yours, mine is so cold now, I should be set for summer.
    I also recently replaced a few bulbs including some of the HEVAC ones, I was lucky to find some of the correct ones at my local autobarn. They had a special case of unusual bulbs and just happened to match what I needed. It's a good idea to take in the bulbs you want to replace so you can be certain you are getting the correct bulbs.
    Cheers, Pete.
    Brisbane, Inner East.
    Quote Originally Posted by benji View Post
    In the USA you can buy air con regas kits in supermarkets and hardware stores and shops like Walmart and Sears.
    None of the crap like here where you have to be a licenced fridgie to buy gas.
    URSUSMAJOR
    Oct 2017
    nowra
    Im ex panel beater i have a aircon ticket Benji
    Just a vac and regas ,
    Just wondering is people know the aircon filters for the outside air are just under the front screen , 2 screws and pull out , mine were full of dust and leaves .
    Oct 2017
    nowra
    R134-a gas
    Quote Originally Posted by Bigbjorn View Post
    true in the states you can buy cans of one shot , they have a shrader valve , you conect the can on the low pressure side open the tap and the gas gets sucked in ,
    1.250 Kg`s is a lot of gas a falcon takes 760+-50 grams
    Oct 2017
    nowra
    bulbs
    Quote Originally Posted by PeterH View Post
    Cheers, Pete.
    Thanks pete ,, $2 each at the local parts store ,, will stick them in today ,,
