Thread: Handbrake elbow lever configuration on 2A
    Dec 2010
    Kiewa Valley, VIC
    The pic below shows how the handbrake lever that bolts to the chassis was configured when I acquired the car.
    There is w shaped bracket/spacer that is seen as resting on the elbow side of the chassis. I think it may be meant to be on the outside of the chassis, acting like a washer/spacer near the nut, but im not sure.
    Can anyone confirm the correct location of this w bracket and what its for??
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Mar 2013
    East Gippsland
    Looks like the sort of clamp that holds brake lines.......will have a look and take a pic of mine if no one comes up with a better answer .....I'm just guessing
    Cheers Paul
    I don't think the W bracket is an original part, but I am away from home and don't have either my 2a or any references.
    One of the problems with this setup is that a heavy load on the pivot will bend the plate that the pivot is mounted on. I suggest this w bracket has been added to alleviate this. I added a flat plate on the back of the bracket, neater, and effective.
    The main reason for excess load is trying to get the handbrake to hold when covered in oil from a leaking seal.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    The bracket is bent. Straighten it and it fits between the chassis and the pivot bracket. The pivot fits into the slotted hole in the chassis bracket and the plate goes behind the bracket and the pivot nut and spring washer hold it all together. There are two slotted pivot holes. The pivot goes into the lower hole from memory. The plate was added for strengthening coz the pivot can twist and break off. The plate adds extra strength where the pivot is bolted.
    Going by ur pic the plate is on the wrong side of the pivot.
    Cheers Rod
    Bit dark for a pic tonight...
    The bracket in its correct orientation. As fitted to late 2a and s3 of course. The gap is where the chassis bracket fits.
    The chassis bracket
    Cheers Rod
    Dec 2010
    Kiewa Valley, VIC
    I can't find any reference in the handbooks or online. No pics anywhere, but it looks original. I can't imagine someone would fabricate this bracket. The nut for the lever axle is conical, which made me think the w plate fits on the outside of the chassis as the tapered end fits into the w hollow perfectly.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Apr 2014
    Ive edited my post as some info was missing or incorrect. Sorry.
    Cheers Rod
    Dec 2010
    Kiewa Valley, VIC
    Great reply Rod, thanks for going to the effort to provide pictures.
    i will straightened the backing plate and put it in the correct spot.
    phillip
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
