Results 1 to 8 of 8
Thread: Tools for touring
    Jan 2017
    Geraldton WA
    Tools for touring
    I may be a little paranoid But when I go away on a trip I usually carry a lot of tools with me, Not only hand tools But power tools, a welder and a decent selection of electrical connectors and odds and sods.
    Along with the various spare odds and ends I also carry this adds up to a fair bit of extra weight But I am reluctant to trim down what I carry because I just know that "Murphy's Law" would kick in if I did.
    What is in your tool kits when you are touring?
    4.6m Quintrex boat
    Canberra, Australia
    I carry 'generic' tools like an 3/8 drive metric socket set, 1/4 drive socket set with allen and torx bits, 6-32mm ring open enders, then my tool box (blue plastic with pliers/hammer/punch/screwdrivers/tie wire/cable ties/electrical connectors/shifter/file etc. Extra stuff: 2.5mm welding rods, welding lens (not whole helmet), tin of selection of nuts, bolts & washers, selection of smaller specialist tools that I have needed on the vehicle (generally these live in the tool box anyway) like 400mm long 1/4 drive extension.
    When maintaining my vehicle/camper I try to use the tools I carry in the vehicle, if I need to get a tool from my workshop, then it is added to the car tools.
    Interestingly I have never really needed any of the specialist tools on my own vehicle, but used a couple of times on others.
    Welding rods, used only once to repair trailer, and got us home.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Jan 2017
    Geraldton WA
    I also carry a container with various sized tech screws in it that have come in very handy on occasions, Also silastic, areldite and metal "putty" comes in quite useful as well.
    4.6m Quintrex boat
    Feb 2005
    I used to carry a big tool kit....now it’s just the minimum
    Common spanners
    Pliers, side cutters, vice grips
    Hammer
    Stanley knife
    Small container of odds and ends
    Selection of screw drivers
    Three shifters
    That’s about it.......
    Tools for touring
    Common spanners
    Hammer
    Stanley knife
    Three shifters
    About all I take -
    and Amalgamating Tape & Cable ties!
    Jul 2003
    Nanocom and the workshop manual on a flash drive...some things you can't fix but others can!
    Mahn England
    Ex 300Tdi Disco:
    North Central Victoria
    I'm a motorcyclist so I'm used to packing light. Metal putty is a must. I generally take my smaller 1/4 inch socket set as it's usually more handy. If I need the 1/2 inch something big is wrong Tools for touring
    Feb 2011
    Richmond, NSW
    I've always been in the 'Sod's Law' camp and have found myself needing a tool I left at home too often, so these live in the car permanently:
    Tool roll Spanners Socket set Electrical box Nuts and bolts box Miscellaneous box Other
    Punches Ratchett set Metric and Imperial Solder Nuts Soldering iron Ball pein hammer
    Screwdrivers Shrink wrap Bolts Electrical tape Large shifter
    Shifter Fuses Screws Silicone tape Large screwdriver
    Stanley knife Bulbs Fixings (misc) Gaffer tape Steel rule
    Pliers - standard Connectors (mixed) 100mph tape Cable ties
    Pliers - needle 12v cable Sandpaper Rag
    Pliers - opposing Torq bits Butane Tape measure
    Wire cutters WD40 Magnetic tray
    Vice grips Threadlocker Gloves
    Grease tube Allen keys
    Silicone tube
    Metal putty
    Bobby
