Thread: Front speakers very low volume
    Jul 2017
    Kinglake
    My recently-acquired base spec D3 TDV6 was bought already fitted with a JVC KW-AV51 a/v unit. The rear speakers work fine but the front ones only provide a very low volume, left and right the same. The fader/balance settings are not the culprit. The 4 sets of speaker cables coming out of the rear of the unit all have power according to the multimeter. Any ideas please? Thanks in advance.
    Dec 2011
    Adelaide
    142.79 MB
    Do you know if they have ever worked correctly or is this a "new" thing?
    If they have never worked correctly, it could be they are the wrong impedance speakers.
    If its a new thing I'm not too sure.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    vee8auto Guest
    you cant measure the audio signal with a multi meter.
    And this thread would be be better located in the car audio etc forum on this site, especially if its just a generic head unit and not a Land Rover optional model.
    Oct 2003
    Montrose, Vic.
    As suggested, I've moved this to the car audio area - being a none standard system, hopefully you will get more help here....
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Jun 2010
    Cairns QLD
    My fronts quieten (not mute) the front speakers when sat nav "speaks" - as in says next turn...
    Not sure how the factory system controls that but possibly a wire plugged or not plugged into the after market head unit?
    Jul 2017
    Kinglake
    Quote Originally Posted by Aussie Jeepster View Post
    The speakers are the original OEM units so presumably they worked when the JVC head unit was installed, although of course I can't be sure.
    Jul 2017
    Kinglake
    Quote Originally Posted by Boof Ed View Post
    I'll check that too. Thank you.
