Results 1 to 8 of 8
Thread: Waeco CFX65 and Traxide 2nd Battery socket
    Jun 2012
    Auckland, NZ
    I have an issue with my Waeco CFX65 fridge not running from the power socket I installed as part of my 2nd battery/Traxide kit. It has previously worked with no issues.
    I’ve tested the socket and it is showing approx. 14v with the engine running. When I plug the fridge in nothing happens. I’ve also measured the voltage at the fridge end of the lead and it is also showing approx. 14v.
    If I plug the fridge into the standard Aux socket in the front of the car it runs fine.
    Does anyone have any ideas on what the issue might be or other tests I can run?
    MY08 Discovery 3
    4.0l V6
    Adam
    in the wild New England, NSW
    If the fridge functions when connected to another socket, AND if (your power cord to the fridge is showing correct voltage (if I have understood what you have posted correctly) , then is it simply that the socket at the fridge is not being fully pushed in ??
    Is there a fuse in the fridge that is dodgy ??
    Just try to logically eliminate each component if it is OK as you try it.
    Ean Austral Guest
    You haven't got the wiring round the wrong way on the rear socket ? Try plugging something else in and see if it works .
    cheers Ean
    Quote Originally Posted by Ean Austral View Post
    cheers Ean
    No don’t!!!
    If it’s the wrong way many devices will blow...
    Use a multimeter.
    Jun 2012
    Auckland, NZ
    Thanks for the replies.
    I'll try the actual socket again with the multimeter to confirm the polarity is correct.
    As I mentioned I have used the fridge in back previously with no issues, however I did have some major repairs carried out on the rear of the car after someone reversed into me (but that's another story). Maybe the smash repairer fiddled with something and wired it up incorrectly.
    Thanks again for the suggestions!
    Adam
    Plug it into the aux socket that works and unplug fridge end and probe there... (take note of polarity)
    Now plug it into your new socket and repeat.
    Safer than trying to get the meter probe down the centre without risking a short.
    Queensland
    Hi Adam, how did you test the voltage at the socket?
    Also as posted above, make sure the polarity is correct, as you posted, the repairer may have disconnected the socket and then reconnected it in reverse.
    Jun 2012
    Auckland, NZ
    Bingo!
    Polarity was reversed despite having black and red cables and the + and - clearly marked on the back of the socket!
    Thanks to Ean for the initial suggestion and Tombie for fine tuning the testing techniques!
    Adam
