Thread: Door Seals
    Narre Warren South
    Door Seals
    Does anyone have a source of door seal that's close to the original.
    Some years back I got some from Clark Rubber, listed as land Rover door seal. The lip is a bit too big, sits too high and the aperture for the steel strip too large.
    Just took delivery of some seal from Paddocks. Aperture for the steel strip not wide enough and almost triangular in shape ? Lip seems to sit too low. I'll guess the manufacturer, probably comes in big blue bags hence ordering only a couple of metres just to see what it was like.
    Local extruder claims they could get it from Malaysia but struggling to get them to quote. Dread to think what it would cost to get a die made and there would probably be a minimum run....
    Is it that hard to get something close to the original ??
    Land Rover Door Seal by Colin Radley, on Flickr
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2013
    East Gippsland
    I used defender seals on mine reasonable price and fitted well
    Cheers Paul
    Narre Warren South
    Quote Originally Posted by bemm52 View Post
    Cheers Paul
    Thanks Paul,
    I'm looking for a seal that's fitted as per original, mainly for my Series I.
    I have the hollow rivets and need to make a clinching tool, problem is finding the correct (or close to original) seal profile.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2006
    The many little things that need fixing on a 1961 Series 2 I acquired from a deceased relative's estate about 18 months ago include door seals. Enquired about them when purchasing other parts from Anthony and Bev Johnson at Bayswater, Vic. Apparently Defender ones will fit with minor modifications. However, reckoned they can get the original type that comes in pieces and attaches with rivets. Undoubtedly would be other LR parts suppliers who could also get them if they can. A bit more expensive than Defender ones. Probably better if desired to keep the vehicle somewhat original where practicable.
    Narre Warren South
    Quote Originally Posted by mox View Post
    I've heard of others mentioning the seals in pieces but need to see a sample before wasting any more money. The seal material I ordered should be able to be used with the original steel strips (if not badly rusted) but the profile isn't close to the original stuff.
    Close to $30 for the front of the door, similar for the rear of the door https://www.johncraddockltd.co.uk/se...seal&sb=Search !!
    I'll keep looking.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2016
    Guanaba, QLD
    Cheers Paul
    Why do you need door seals Paul? You don't even have a roof!!!
    Mar 2013
    East Gippsland
    Quote Originally Posted by OneOff View Post
    But my windscreen wipers work
    sorry to hijack the thread but I had to bite
    Cheers Paul
