Results 1 to 6 of 6
Thread: What diff has my '68 2A been fitted with
    Oct 2017
    Kilcoy
    Hi guys,
    I guess this is a perennial question, and has been asked a million times before, but could not find anything on the forum that popped out at me. Mine is an ex ARMY 109 with the rear diff having no rear cover but the pinion/carrier assembly can be removed from the front of the diff housing. Is this a Rover diff or ?? Then waht axles is it likely to have fitted? Not really interested in converting to Salisbury type as I want this to be restored to as close to original as possible.
    Barra
    May 2008
    Bundaberg Qld
    Should have a standard Rover diff (and axles) with 4.7 ratio
    Free Again Thanks Dan
    Quote Originally Posted by pop058 View Post
    X2
    Narre Warren South
    As above, Should look identical to the front.
    A couple of pictures here......2a GS Refurb ARN 178-334
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    As above - 68 should be a standard Rover diff, looks the same as the front one, and should be 4.7:1. The Salisbury diff was not even optional in 1968, although some have been fitted (S3 one is a bolt-in change with prop shaft from the S3, lwb only).
    Oct 2017
    Kilcoy
    What Diff is fitted
    Thanks guys - correct as usual. I rec'd my LR parts book last night & had a quick look to confirm it is fitted with Rover diffs. I wasn't sure if Rover or ENV were fitted but now I know & confirmed by you gentlemen.
    The ARN of my vehicle by the way is 174-803 (109 GS) & i found a unit colour plate behind the typical Tri-service plate fitted in the TAC plate holder. this has got me a little closer to its origins.
    Neil
