Results 1 to 9 of 9
Thread: 2.2 or 2.4lt motor for a 130? Any tips, problems or preferences??
    Nov 2017
    Preston
    Hey guys,
    looking at getting a 130.
    whats a better motor 2.2 or 2.4lt??
    has anyone had any experiences good or bad with that motor??
    any help would be great.
    Cheers jared
    Nov 2014
    Sydney NSW
    The 2.2 has been around longer and in many different vehicles. The 2.4 in the defender does have some cooling issues and heads have been know to go, not as common on 2.2s.
    The 2.2s can make slightly more power. The radiator is also better on the 2.2s than the 2.4 apparently, Bruce Davis told me this so ill take gis word for it
    Nov 2017
    Preston
    Ok cool, so the problems with the heads. Is that a high kms issue?
    Is there anything you can do to prevent these issues?
    Nov 2014
    Sydney NSW
    Quote Originally Posted by BlackD90 View Post
    The 2.4s have a tendency to overheat more so than the 2.2s. They also go into limp mode more often as a result
    Nov 2017
    Preston
    So is there anything you can do to prevent?
    Or or just stick with the 2.2?
    Quote Originally Posted by 1nando View Post
    Nov 2014
    Sydney NSW
    Better radiator, needed if tuned no compromise ( this was recomended by dpl). Fan spacer replacement is recomended. Better flowing intercooler. Decat also helps. Let the engine breathe better and upgrade the cooling system and she'll be right
    Nov 2017
    Preston
    ****! So your better off spending the extra money on a newer 2.2 then. Thanks for the turn off!
    Brisbane, Queensland
    Search for Digger’s experience of the 2.2, which apparently the better motor of the two. Patience of a saint. Some have had no dramas.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Nov 2017
    Preston
    Thanks for the hot tip.
    Ill check it out!
