Results 1 to 10 of 12
Thread: AM/FM antenna for Defender
    VladTepes's Avatar
    Bracken Ridge, Qld
    (So as not to clutter the thread in the D2 forum)
    I don't mind the UHF antenna on teh passenger side of the bullbar (mostly because it's not in front of me ) but I don't want another one on the drivers side of my 130 Ute.
    I previously had an el cheap spring base antenna on the RH guard in the standard location. Now that was OK as it could bend against brush, trees etc and not snap but it did get caught up in the snorkel from time to time.
    So Defender owners - what antenna have you got, and mounted where?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    My uhf and Telstra antenna are on the headboard.
    Australia
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i am getting one of these for the 130
    GME AEM2 AM/FM Fibreglass Antenna - RYDA ($53.85)
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Similar to Inc, a Mobile One antenna 1000mm or 1200mm whip with HD spring mounted in the factory position.
    Mobile One Antennas
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    VladTepes's Avatar
    Bracken Ridge, Qld
    Is it possible to mount on the LH guard or more trouble than it's worth?
    If in the factory position - what cable length is needed?
    gone
    1996 Discovery 1
    current
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by VladTepes View Post
    normally aerials come with about 4m of cable which should allow you to put it right up the front of the left guard and then some as you would need 3m at the most IMHO
    VladTepes's Avatar
    Bracken Ridge, Qld
    I just wondered because I see they sell it with 2m, 3m or 4m cable lengths.
    gone
    1996 Discovery 1
    current
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    2m lead should be sufficient to mount in factory position.
    another benefit of the 1200mm length mounted in the factory position, it is the same height as the roof rack. It’s an impact early warning system.
    MLD
    VladTepes's Avatar
    Bracken Ridge, Qld
    But not as high as my canopy with roof rack....
    gone
    1996 Discovery 1
    current
