Results 1 to 10 of 11
Thread: Rough Price For Air con Regas
    Mar 2012
    Armstrong Creek, Qld
    What would be an average price I can expect for a D1 3ootdi Regas?
    May 2014
    Tamworth NSW
    Which gas?
    R134a or something else?
    The older gases are no longer imported in significant volumes, and supply/demand drives prices up.
    There should be a refrigerant info plate under the hood somewhere.
    -Mitch
    'El Burro' 2012 Defender 90.
    I was told that it is not legal to just regas without first checking for leaks. That makes it a bigger job.
    I assume I was told the truth.
    Aug 2010
    Sunbury, VIC
    A quick squirt of LPG will keep it cool for the Summer....
    ducks for cover and runs...
    Jan 2017
    Geraldton WA
    Quote Originally Posted by vnx205 View Post
    I am pretty sure that this IS the case and also not checking for leaks and just re gassing is a pointless exercise because the gas must have escaped somewhere and fixing the leak Before re gassing makes absolute sense.
    Other wise it would be the same as having a flat tyre and just airing it up again in the hope that it will stay inflated instead of fixing the puncture first.
    4.6m Quintrex boat
    Mar 2012
    I don't think it's a leak it's just that it's not as efficient as it was plus, it's the original 1997 gas.
    May 2013
    Bittern Vic
    if you have had the vehicle for several years and the air con worked well in past years , you could just add gas and hope it keeps going.
    My air con man adds some leak dye to the gas and after a few months the dye appears on the outside somewhere showing where the gas is leaking from and what needs replacing. and why the system needed topping up in the first place.
    I think I pay around 200 for him to add gas and the leak dye , and he does this in my driveway which is very convenient and saves a lot of my time.
    I hope this helps
    Ian
    Bittern
    Brisbane,some of the time.
    That is the truth.
    Back down the hill.
    Quote Originally Posted by Toxic_Avenger View Post
    Which gas?
    More likely to be under the bonnet.
    May 2014
    Tamworth NSW
    Oh, really?!
    -Mitch
