Few things you can check yourself
- is compressor clutch engaging?
- if engaged is one pipe getting hotter than the other. (Check check with back of hand )
- is there power to compressor clutch
- are there any visible leaks - if it had dye put in last time.
- are all the relay terminals clean and fully home
No doubt one of the fridgees on here will tell you which pins to short out on the pressure switch to over ride a low gas level.
Finally good results with hychill 30 in Defa systems as the refrigerant.
