EAS Valve Block question
					I am wanting to fit the GOE EAS system. When I look at the valve block diagram in the D4 Manual (Page 12750 it shows different connections to the GOE instructions. In fact the manual says the valve blocks (front and rear) similar, yet the front one shows air inlet/outlet connection to the side (no 7), and the rear its in the middle (no 10) which is the same as the GOE instructions. Can anybody confirm or otherwise the correct connections for a D4. I dont want to unnecessarily undo a hose if I dont need to.
				2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
