Results 1 to 10 of 26
Thread: fishing a stick out of a fuel tank
    Feb 2013
    Ballarat,Vic,Aus
    Hi Guys,
    I know a genius .... who doesn't need to be named that dipped the petrol tank on the tractor too see if there was enough fuel in it to cut the grass..... and managed to drop the stick I can see it down there with a torch floating happily. I'm not really keen on it breaking up and making a mess of the fuel system. Surely there is other poeple out there as stupid as ... er ... "this person" so have a smart way of retrieving the stick.
    The simplest way I can think of it to just fill the tank ... It will sit there floating at the top for me to grab with two fingers .... So I looked at the specs. The damn tank hold 80litres I don't have enough $$$ to spare to fill it (not to mention filling it 20litres at a time from a drum is bloody hard work!).
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Slip line with fishing line.. etc and lasso it.
    May 2008
    Bundaberg Qld
    disconnect the fuel line, drain the tank, fill with water, retrieve stick, drain water, flush (maybe a couple of times with the same 5 litres of juice), refill tank with the good fuel you have left.
    Jul 2009
    Hobart
    Hi,
    Length of copper 13mm pipe.
    Length of whipper line cord.
    Pass a loop of cord down the pipe and snare the stick.
    Pull tight and retrieve said stick.
    You may need a 90 degree elbow on the bottom of the pipe if the stick is going to be at an angle that jams coming out.
    Quote Originally Posted by DoubleChevron View Post
    Hi Guys,
    seeya,
    Shane L.
    The press button flexible grabbers used for making gardens in a big bottle would be your friend. Big nursery would have some, about 2 foot long.
    There are so many ways of doing this, I'm surprised it needs posting. Good luck with it and let us all know the outcome.
    DL
    Oct 2007
    Wantabadgery, N.S.W.
    Chop a hunk of fabric from your wife/partners stockings/pantyhose. Tie a strip of it to a much sturdier stick than that used by the clown who caused all this, then poke it in the tank and wrap it onto the floater. The little fibres will hook on to the stick and won't let go. Fish it out
    Don.
    Jul 2009
    Hobart
    Back down the hill.
    Quote Originally Posted by Don 130 View Post
    Don.
    That's a bit self serving, why can't he use his own panty-hose?
    Irymple, Victoria, Australia
    Wood Magnet from "Big W" or ask Santa to bring one to you for Christmas!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Apr 2015
    Lillyfield NSW
    Put on a mask and yell down the filler; This is a stick up.
    Cheers, Billy.
    Keeping it simple is complicated.
