Results 1 to 6 of 6
Thread: New Auxiliary Battery search
    Scarborough, QLD
    So, it seems the 120Ah AGM deep cycle from my camper may have packed it in. Went and retrieved it today, to notice it was reading 7.76V Not sure why, it doesn;t get much use and is normally constantly on the solar charge when not in use. This time, it sat idle for 3 weeks (or I thought) without the solar. No idea what caused it to plunge, given the only draw was the solar regulator LCD panel.
    Anyway, should it be kapput, I'm wondering what to replace it with. Is lithium a real option yet? Is lead crystal the real deal? Or do I just grab another tried and tested AGM?
    Any suggestions?
    LiFePO4 is still about $12-1400 for a 100ah (equivalent of 160ah AGM battery in useable capacity)..
    Sep 2012
    Adelaide Hills
    i like yellow top or calcium
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Queensland
    Hi Ranga, do you have an electric winch fitted, if so, go for a Yellowtop.
    If no winch, then a Lead Crystal is your best option.
    Lead Crystal batteries can be left unused or uncharged for many months, so they might be better for your specific type of use.
    Have a look at the link below and let me know which Lead Crystal you are interested in and I will give you a quote.
    BTW, I think you will find the biggest Lead Crystal battery that will fit under your seat is the 6-CNFJ-65, which is a 72Ah battery.
    Product range
    Apr 2007
    NW Tassie
    Quote Originally Posted by Ranga View Post
    Any suggestions?
    Had the same happen to my caravan, 2 x 100 amp batteries connected to solar reg and both went flat, real flat. My regulator turned out to be stuffed and was letting the panels back feed. All fixed with a new regulator
    blaze
    Scarborough, QLD
    Product range
    Hi Tim,
    This is for inside the slide on camper, so no winching. I'd be interested in the 6-CNFJ-100 or 120.
    Sent from my Redmi Note 3 using AULRO mobile app
