Results 1 to 10 of 27
Thread: Help need
    Adelaide
    Help need
    Hi my sister is stuck in Waikerie in South Australia . Her daughter put 15 l of petrol in her discovery 4 diesal.The car has not been move but she is scared that the tow truck driver is going to turn the engine to load the car.If anyone is in the area would be able to find fuel pump fuse and pull it
    Your help would be much appreciated
    All the best
    Ben
    Ben
    Disco 1997
    Divers do it deeper
    Adelaide
    fuel pump
    Could Anyone be able tell me where the fuel pump fuse is on a Discovery 4
    Thank you
    Ben
    Disco 1997
    Divers do it deeper
    Jul 2015
    Taupo NZ
    how about disconnecting battery, or taking another fuse that will stop it starting.
    NSW SW Slopes
    If the towie is concerned at dragging the vehicle whilst in Park then remove the cup-holders and lift the little while lever on the right rear of the gear selector panel to allow the lever to be pulled out of park.
    If the handbrake is on then also under the cup-holders is a wire cable loop which if pulled hard (using the wheel brace or similar tool) will release the handbrake.
    Engine bay fuse 1 is for the fuel pump. Also, fuse 4 for ecm fuel pump relay control.
    DiscoMick Guest
    The SA motoring organization should be able to organize to get the tank emptied.
    Oct 2013
    Old Toongabbie, Sydney NSW
    Would 15 litres be ok with a full tank of diesel? I recall other threads where people had no ill effects with small amounts of petrol mixed into a full tank. Be careful though to get a more expert opinion, I'm just recalling what was discussed previously.
    Martin
    Mar 2007
    Warwick Qld
    You could get away with some petrol in the older diesels, NOT with Common Rail ones. Drain the tank and be safe.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Oct 2012
    No one will guarantee anything other than 100% Diesel including me but I reckon 15 litres in a chocabloc full tank would not do any harm.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    I thought those things had a missfuel device fitted
    Mar 2016
    Help need
    Quote Originally Posted by 67hardtop View Post
    They do, so they won’t be starting it anyway even if they tried. I assume the electronics stops it starting when triggered but maybe that’s too sensible?
    2007 Audi RS4 (B7)
