Results 1 to 10 of 35
Thread: LRA Hydroboost Brake Upgrade Kit - replacement for vacuum pump assisted brakes
    Feb 2011
    Hobart, Tasmania, Australia
    Question LRA Hydroboost Brake Upgrade Kit - replacement for vacuum pump assisted brakes
    So, anyone used the Les Richmond Automotive Hydroboost Brake Upgrade Kit?
    Hydroboost brake upgrade kit
    Brake booster upgrades for Land Rover, Range Rover Classics and Discovery Series 1 and 2
    This kit is designed to increase the brake pedal response and reliability. By removing the vacuum assisted booster and master cylinder and replacing it with a hydroboost unit kit which instead of relying on vacuum from the engine or an inadequate vacuum pump on diesel models uses 1000psi of hydraulic pressure piggy backed off the existing power steering system. Perfect brakes every time no matter how many times you apply the brakes. Also increases brake pressure at the calipers for far superior brake efficiency.
    A must for .... Towing, Larger Tyres etc.
    Perfect brakes every time.
    Pateyw Guest
    Yes have fitted a hydroboost brake system to my defender .
    its not from LRA but it works a great deal better than the standard brake system.
    Also it hasn't affected my steering as some would have you believe.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    No brake assist when engine turned off????
    Like old c20 chev utes or trucks????
    Oct 2012
    FNQ
    Some info in my members ride thread
    Free Again Thanks Dan
    Quote Originally Posted by 67hardtop View Post
    No Different to vacuum assisted brakes on 99% of cars
    Apr 2014
    Still get a couple applications b4 u lose the brakes. Was asking the question not making a statement. Thats usually what these things???? mean.
    Cheers Rod
    Dec 2012
    Stuart Town
    Lose the fan belt and lose your brakes? No thanks.
    Tom
    1996 Disco 1 300TDI manual - Lucille a cantankerous red head! :D
    1997 Disco 1 300TDI Auto - sold
    Jul 2011
    Yarrawonga, Vic
    I fitted a Hydroboost & Mastercylinder from a 2006 Suburbain to my Iveco inplace of the dual diaphragm booster & Bosch MC on my iveco . The braking is vastly superior , I get 5 full power pumps after engine switched off due to the accumulator on the HB unit . No change to steering even at walking pace / parking speed. Best thing since sliced bread . The PS pump on the Iveco as on the Defender is driven from the timing mechanism, so belt failure thing is a furphy.
    May 2009
    West Gippsland - Victoria
    The Oka has a 4 wheel disc brake hydroboost braking system as standard with front and rear disc/calipers the same. Not bad for an early 90's vehicle and with the hydraulic pump cam/gear driven brakes and power steering are independent of the fan belt. A very efficient and reliable way of doing things.
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    Feb 2011
    Quote Originally Posted by BathurstTom View Post
    I think you would only loose the assistance to the brakes. Isn't the vacuum pump on the engine currently fan belt driven anyway so no change?
