Results 1 to 10 of 12
Thread: 300Tdi Front Exhaust Pipe
    Scarborough, QLD
    Mine's rusty (with a hole in it), so I need to replace it. I put fibreglass wrap on it about 5 years ago. Not sure if this has caused (or assisted) the rust. Would stainless be worth the extra cost?
    Feb 2005
    I’m not convince stainless is worth the cost given how long a mild steel one lasts.......stainless also work hardens which may lead to cracking.
    What’s the cost difference??
    Scarborough, QLD
    Not sure on price difference. I thought of using stainless to avoid the wrap causing rust. I've had conflicting advice saying wrap does and doesn't cause rust. Perhaps mine was rusty already, who knows?
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    I've never seen it cause rust
    done it to way too many vehicles and not seen it on any.
    stainless is okay if you fit a flexi joint, but i fit them anyway as it makes for a more pleasnt ride.
    personally, i wouldn't bother with stainless on a defender....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    NSW far north coast
    What weeds and Inc have said.
    Aluminised steel seems to last so long in Australia on a turbo diesel, unlike the northern hemisphere where salt is used on the roads in winter.
    The 3" black steel dump pipe I made rusted out badly under the header wrap as the high temp paint I used failed.
    If I'd had it mandrel bent out of aluminised pipe instead of me cutting and welding mandrel bent sections it'd still be ok.
    Just use normal aluminised steel and get pipe ceramic coated. More efficient than exhaust wrap. Coating goes on both external and internal surface
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Scarborough, QLD
    Quote Originally Posted by 86mud View Post
    Is the ceramic coating applied by the muffler place, or somewhere else? Any idea about cost, and good supplier?
    NSW far north coast
    Quote Originally Posted by Ranga View Post
    No, you have to send it away to places like HPC or Jet Hot.
    I agree, that's the ultimate way of doing it.
    All my exhausts on my 110, factory, Taipan and now local shop all rusted/rusting. Gold Coast and park at the beach a lot (not on the beach)
    NSW far north coast
    Quote Originally Posted by uninformed View Post
    Every time I go to Lennox now all I drive through is sea spray/mist.
    My poor Disco, gone from 15 years in the dry desert to....
    At least the exhaust is stainless! 300Tdi Front Exhaust Pipe
