Results 1 to 10 of 17
Thread: Sunroof Switch Blank in Roof Console
    Brissy! No flannos here!
    Hi all,
    I read in another thread, either here or Disco3, that one of the commonly available brand of switches is a near perfect fit in the sunroof switch cut out.
    Problem is I can't now find the thread!
    From memory it was Narva or maybe ARB.
    I'm looking at options to mount a USB plug and thought that an existing profile would look neater.
    Cheers in advance.
    Ralph
    Oct 2016
    Perth, AU
    I read this on Facebook the other day - Carling switches I believe?
    Log in to Facebook | Facebook
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Quote Originally Posted by veebs View Post
    By Joves you are right!
    That's where I read it...
    Cheers and thanks...
    Ralph
    St Helena,Melbourne
    4.28 MB
    But do you want a cable hanging down , if I read that correctly.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2014
    I did this. I like that the switches are square & small like the factory light switches but I wish they had a lower profile.
    It seemed a reasonable compromise so as to only put holes in the little blanking plate.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Nov 2015
    Black Rock
    I've just fitted a dual usb port in the top glovebox compartment. There's heaps of room behind the LH end cap. Simply piggy back off fuse P52 (20amp) with a 10amp fuse in your new circuit. Use 5mm auto wire. Earth to one of the earthing points in the footwell. All neat and hidden away. You could also do the same in the top shelf, but it would be a bit more fiddly. There's a bit of room behind the rear panel at the left hand end.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Dec 2014
    Quote Originally Posted by DieselLSE View Post
    Did you take the panel out to do this or insitu?
    Nov 2015
    Black Rock
    Quote Originally Posted by plusnq View Post
    The end panel has to come off, but it simply pulls away. And the lower glovebox has to be lowered to gain access to the fusebox of course. And the footwell panel needs to be removed to gain access to the earth bolts. But the upper glovebox remains in place. A step drill bit is easiest to use.
    Quote Originally Posted by LRD414 View Post
    Hi Scott,
    What do you switch with them thar switches?
    Ralph
    No, but I am only starting to look at options and ideas.
    Ralph
