Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Sway Bars
    Sway Bars
    My Defender is a 200tdi. However it is a late one. On the rear and front i think is mounts for sway bars. On diff and chassis.
    Is there any advantage in using them?
    Mar 2007
    Canada
    They reduce sway and they reduce articulation.
    Jul 2008
    If you're doing heavy laden desert trips with lots of high speed highway - install;l them
    If you're looking for an pure or mainly off road truck on uneven track with low speed work take them off.
    There are many threads on this topic
    Clive
    Mar 2007
    Canada
    If you want both you can get the ones with disconnects on them.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Some would argue to fit them to the rear and not to the front. That set up restricts flex in the rear to match the front making for a more balanced 4wd off-road. That assumes you stick with the factory geometry set up (i.e. the OEM shock length). If you mess with the factory geometry it can lead to inverted sway bars.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Feb 2005
    I didn’t have a sway bar on the tdi and had nothing to compare against. My TD5 has one on the rear, I run stand suspension on the front and air springs on the rear......I think a swag bar has its place for a tourer.
    Sep 2009
    My td5 dosnt have them.
    Its just a tourer and i dont feel that i really need them.
    If i had a car with them though id wouldnt remove them.
    Mar 2007
    Warwick Qld
    My D1 has a 50mm lift, and the standard sway bars used to invert themselves all the time. Added 50mm spacers and problem solvered.
    The ride difference with it loaded for touring is huge! I wouldn't be without them.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Aug 2017
    AU
    Quote Originally Posted by MLD View Post
    Unless a car is designed from the factory to not have a front bar and have a rear bar, and i cant think of one like that, its generally considered unsafe because it generally promotes oversteer.
    May 2006
    Woolgoolga
    Quote Originally Posted by Red90 View Post
    For a small fortune!Sway Bars
