I’d run 6B&S cable to the rear of the car from your AUX battery or isolator with Anderson plug fitted.......assuming you have portable panels with regular fitted. The Anderson is ther if you ever hook a camper/caravan up.
Slightly better set up is to have your regular fitted as close to the AUX as you can than run cables from there.
No need for complicated setup.
