Transmission and EPB wiring under the centre console including a few plugs.
Something knocked or loosened?
Yesterday i had the center console and dash fascia off while i hooked up the power lead for my UHF and fixed an intermittent fault with the aux input i added to the stereo.
I musnt have used the correct procedure to remove and install the console as i got a transmission fault just after startup and then this morning after 20mins i got a HDC not available, suspension lowered and an orange handbrake icon on the dash. I pulled over and shutdown waited for 10 secs then restarted and back to normal until almost home tonight when i got the same erorrs ?
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Your battery needs a charge.
And the vehicle was awake so discharging all day whilst you worked on it..
 Master
						Subscriber
						Master
						SubscriberI personally never do, but I charge mine regularly.
And I run an odyssey battery. It charges much much quicker.
Thanks Mike makes sense, just put the charger on and will leave it overnight.
1974 VW Kombi bus
 Master
						Subscriber
						Master
						Subscriber Master
						Master
						2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
