Results 1 to 10 of 11
Thread: THEMS THE BRAKES OR NOT
    St Helena,Melbourne
    4.28 MB
    The rangie's brake m/cylinder has sh@t itself and even after fitting new seals its still leaking, gonna bite the bullet and go new but they are a bit exxy at approx. $345. I can get one from the UK at about $140 + postage.
    Anyone bought one locally for reasonable money ?
    Williams West Aust
    Hi
    Have you looked at Karcraft???They are very good on prices,both genuine/non genuine
    www.karcraft.com.au
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2002
    Heathcote (in "The Shire")
    Why not get it re-sleeved with stainless, any good brake place should be able to point you in the right direction or organise it for you.
    Bushie
    Adelaide Hills. South Australia
    I agree with Bushie. SS sleeves are a good move. Here it's done by Power Brakes but Vic. would have someone surely.
    http://www.powerbrakes.com.au/
    Under "Resto Info",I notice they have a turnaround of 5 days.
    St Helena,Melbourne
    4.28 MB
    I have thought about re sleeving but unless it is a lot cheaper than a new one its not worth it, change over is about $185+ and a new one is 60 pounds +freight.
    But they could still do you for GST on arrival. Starting to sound expensive imho.
    The thing with SS sleeving is that it won't corrode ever again so it's a lifetime thing.
    Bang them off an E-mail & then you'll know.
    I thought the idea of a SS re-sleve was that it is the end of your problems forever? No corrosion
    The other option is to use silicone brake fluid. It's only allowed to be used in non-abs cars, but it doesn't absorb moisture, so reduces or stops corrosion problems. I use it in the lotus. Once it's pure in the system you never have to change it again
     2005 Defender 110 
    HSVRangie Guest
    Resleeve with SS aprox $160-180
    Michael.
    St Helena,Melbourne
    4.28 MB
    No gst and no duty, and cheaper than re sleeve. Karcraft want $241 but wont have any for 6 weeks
    St Helena,Melbourne
    4.28 MB
    Does anyone know if the master cylinder and booster from a 95 disco will fit my 85 rangie ?
