Results 1 to 8 of 8
Thread: D2 auto failure
    Sep 2010
    The Hills.
    152.79 MB
    D2 auto failure
    The saga continues. The 2nd hand 4HP22 supplied has failed in under 100k. It was driving great. I had to stop for traffic and when I tried to move off it shuddered and then failed to proceed. My first thought was the A clutch, however reverse is fine, so I guess that’s ruled out. Anyone know enough about these to hazard a guess as to what has failed?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    Nanocom reports 722 Stall speed monitoring and 705 Position switch monitoring. Doubt if that helps, but there it is.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Ferntree Gully, Vic
    Quote Originally Posted by johntins View Post
    The 705 code i think is from the xyz switch. I had that code with my brothers disco. Was clunking in gear when when the 2 m and s lights were flashing. Adjusted it and it was ok.
    Sep 2010
    The Hills.
    152.79 MB
    Thanks, Chris. Seems likely. However, I doubt it's the cause of the problem. It should just go into limp home mode, but I have no forward drive at all.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2017
    Geraldton WA
    Have you tried 1, 2 and 3 instead of D to see if you can proceed?
    4.6m Quintrex boat
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by trout1105 View Post
    Yep. Many times. At first there was a little motion, enough to get me across 3 lanes of the Monash to the emergency lane. Now there is nothing at all, except reverse which is fine.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2014
    Nirvana near Albany W.A.
    Would be worth changing the valve body , if your lucky ( which, lets face it that its about time you were)it might have a bit of crud in one of the ports , can happen with 2 hand hand trans that have been sitting around a while , can be done in car, v8 have the same valve body as well
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by discorevy View Post
    Thanks. I can't really make it any worse, can I?
    I found this excellent tutorial. ZF 4HP22E Valve Body Rebuild
    Obviously there are differences, but the job is pretty much the same.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
