Results 1 to 10 of 12
Thread: Number of splines steering shaft
    Cessnock NSW
    I'm asking a question for a friend, can anyone tell me how many splines there would be on a 1995 model 110 Defender steering shaft, as he wants to put a different steering wheel on his vehicle, he doesn't like the shape of the original wheel, he needs to know so he can get the correct boss, many thanks cheers Dennis
    Garfield, Victoria
    I would recommend a search of the forum, as this subject has been discussed a lot.
    There is some information on Exmoor Trim website: Slimline Boss - Small - 70mm PCD | Exmoor Trim
    You will find this at the bottom of the page.
    FITTING
    Available in either 36 or 48 spline boss.
    Land Rover were very inconsistent in their use of 36 & 48 spline steering columns. We recommend removing the steering wheel and counting the splines for guaranteed fitment. The below is for guidance only:
    48 spline bosses were used on Defenders from 1993- 1998 or base spec vehicles from 1998-2008 and any Defenders from 2008 onwards. 48 spline boss will NOT fit County specification and all XS specification vehicles from 1998 to 2007. Will also NOT fit earlier Defenders from launch date up to 1993 regardless of interior spec.
    For all options where a 48 spline boss will not fit purchase our 36 spline boss
    As well as early models the 48 Spline Boss will also universally fit all post 2015 Defender. The boss has been cleverly design with slot to accommodate the revised indicator cancelator set up
    Your attention is drawn to the bold sentence, as you can be surprised!
    Lionel
    Oct 2012
    FNQ
    Should be 48 but one sure way
    AM
    Oct 2017
    AU
    Just remove the steering wheel.
    With 21mm socket
    Use the phone to take a photo of the spline and put it on TV zoom in and count.....
    You never know unless you count it.....
    Cessnock NSW
    Thanks for the responses gents, I have passed this info to the owner of said vehicle cheers Dennis
    Hervey Bay, Qld
    Quote Originally Posted by martnH View Post
    With 21mm socket
    Q; Do you count the peaks or troughs?
    NSW far north coast
    Quote Originally Posted by cucinadio View Post
    The raised bits which are the actual splines. Number of splines steering shaft
    Oct 2012
    FNQ
    either
    NSW far north coast
    Quote Originally Posted by Ancient Mariner View Post
    either
    Just not together Number of splines steering shaft
    Jun 2008
    Drouin East, Vic
    Count the peaks and the troughs, add them together and divide by two.
