6th March 2006, 10:59 PM
6th March 2006, 11:13 PM
1.turn the temperature knob to the min setting you may have installed it upside down .
2 check if you have a relay turning the compressor on it my need replacing
3 if above is not working for you call the manufacture and ask for help
6th March 2006, 11:19 PM
Check at the back of the fridge that the dangly part of the thermostat thingy is not touching the cabinet.
6th March 2006, 11:23 PM
#4
Yeh,
Thanks Kai.
Was gunna rip the back off as soon as I get time and look for the exact same relay :wink:
Roger
7th March 2006, 12:02 AM
#5
Had the same problem on my F&P last week. Frost free no longer. Repair guy came replaced heater element and one of the fans. All better now.
Simon
7th March 2006, 01:07 PM
#6
ok, first Q, frost free or cyclic defrost ??
7th March 2006, 01:15 PM
#7
without having a look which is a bit hard over the internet.
when you replaced the thermostat the probe is usually is attached to the evaporator. if for some reason it is not touching (normally there is a small clamp of some sort there) then the thermsotat is not getting the signal that the fridge is cold enough, hence it keeps running.
That is one option the other is as stated above the the new thermostat may work backwards to the old one, so you may have it turned to it's coldest setting instead of warmer.
Is the fridge a cyclic style? because if it has an internal defrost timer, that could also be buggered and it just keeps running.
If that doesn't fix it then you would have to give me the model and make so I could have a quick look at the wiring diagram of one for you.
cheers Blythe
7th March 2006, 09:55 PM
#8
Thanks all,
It is a Frigidaire 410litre upside down jobbie.
Model number FB410F-01 with 'cyclamatic defrost' 8O
It is beginning to sh*t me. Thawed lettuce on my lunch is horrid.
On the w/e it gets pulled apart and if it is a really good fridge that can be fixed, it will go back together :roll:
Ralph
8th March 2006, 04:50 AM
#9
OK, it's a cyclic defrost.
First up, when the evaporator (the plate in the back of the frig) is frosted/iced, does the ice pattern go all the way across the plate, or is there only partial coverage ?
To really check, do the old lick the finger test and see if it sticks all the way across the evaporator.
If this works all the way, the refrigerant charge is probably OK.
If not, there is a shortage of refrigerant. What happens here is that the part of the evaporator the t/stat feeler bulb touches doesn't get cold enough to cycle the compressor off, causing the frig to run too cold and freezing everything inside.
8th March 2006, 08:12 PM
#10
