Results 1 to 10 of 13
Thread: Manifold and head clean?
    Jan 2018
    Guyra
    Hello,
    Any tips on how to clean a head, manifold and block, removed from TD5?
    Is oven cleaner and rinse safe?
    Feb 2017
    Deception Bay, Qld
    The best is a engine rebuilders cleaning tank for a couple of days but in Guyra that might not be possible,
    My manifold wasn't that dirty so i just used degreaser and made a couple of mops out of scourers and stiff wire, I wasn't that happy with it.
    The modern oven cleaner isn't as good as the stuff from 30 years ago.
    Dec 2016
    Woolgolga
    Which manifold do you want to clean?
    Jan 2018
    Guyra
    Quote Originally Posted by whitey56 View Post
    Would definitely be a long shot, but stranger things have been known to happen..
    Notice there's some online chatter in regards to pitting, resulting from use of oven cleaner; I have not found proff of this.
    Jan 2018
    Guyra
    Quote Originally Posted by Mal View Post
    Inlet, packed with gunk.
    Will replace exhaust manifold with an erg-less one.
    https://www.aulro.com/afvb/asset.php...0&d=1519370128
    Dec 2016
    Woolgolga
    Brake cleaner generally works well with some scrubbing, Careful using oven cleaner on alloy as sodium hydroxide and aluminium don't play nice together.
    The exhaust manifold can be cleaned in a caustic tank .
    Jan 2018
    Guyra
    That was my concern. Hmm
    Not suitable for alloy parts, but the dishwaher will do well if your wife is away. For alloy, my vote would be brake cleaner, but a good soak in mineral turps and a stiff bristled brush will probably also work.
    Jan 2018
    Guyra
    I will give the manifold a cycle in the dishwasher.. Even though it apparently doesn't do the dishes properly...
    I Will get some brake cleaner.. I've got plently of time so might organise to get it bathed.
    armidale
    You could try Engine Reconditioning - John Fowler Automotive - Armidale Mechanic Subaru Parts & Service had cyl head cleaned here a while ago came back looking new
