Results 1 to 9 of 9
Thread: Inspection of head/ block
    Jan 2018
    Guyra
    Hello,
    Can anyone pick up on any faults or give feedback on anything you think should be done/ replaced?
    Melrose SA
    The surface of the head would be of greater interest
    Quote Originally Posted by Hunt family View Post
    Hello,
    Apr 2007
    NW Tassie
    I would clean, remove valves, remove injectors.
    Check the surface of the head with a straight edge, corner to corner, across the width of head for total lenth, end tto end right across the head to check warpage. Check all ports for signs of cracks, check valves for correct seating (nice thin seat in the middle). Clean then clean some more. Then if all is ok reassemble with all new seals and orings etc
    blaze
    ps, You should also check your bores with an internal micrometer
    Jan 2018
    Guyra
    Quote Originally Posted by bblaze View Post
    blaze
    Solid advice, thank you Blaze
    Melrose SA
    Check for corrosion in the water galleries of the head. If corroded some of them go near the fire ring on the surface of the head this will cause you issues if the wrong coolant has been used.
    Jan 2018
    Guyra
    When replacing valve seals, what do I need to look out for? I am a bit hesitant, after reading the write up in good oil, due to the warnings of catastrophic failure.
    I bought the timing pins; however, understand the cam needs to be removed for valve seal replacement. Will the timing be affected , or do I simply line the cam lock with the locking hole before refitting the head?
    Nov 2014
    Nirvana near Albany W.A.
    Yes , remove everything, as you will need to inspect and probably get a light skim on the head unless its warped, change the exhaust manifold studs , make sure you use new , good quality head bolts , and head fitting kit , if sub 200 000 k , doing the valves is maybe not necessary, up to you, but with the cam out , fill the ports with petrol and make sure there's no leakage through the valves, I'm yet to see a valve leaking on td5 with less than 300 000 k , yep , set the cam with the locking pin before refitting.
    Jan 2018
    Guyra
    Quote Originally Posted by discorevy View Post
    Considering it's over 100,000 km until that figure, it might be worth holding off on the valve seals until the time comes for a rebuild.
    My main concern is the adjusters: making sure I do it right.
    Nov 2014
    Place the hydraulic lash adjusters in order from 1 to 10 , 1 being the front in a box ( tight fitting box so they can't get moved if accidentally knocked) check that they are all the same height, keep the injectors in order as well , number them if you need to, otherwise you'll need to code them to ecu.
