Thread: Defender t-case input shaft changes (about to fit PTO Drive)
    Feb 2005
    I’m guessing it’s called the input shaft......it’s the shaft you can inspect when you remove the round cover/inspection plate.
    Im booked in to have my Thomas PTO Drive fitted this Friday.
    They advised Land Rover stopped getting the spline machined onto the shaft at some stage. They indicated a shaft from an earlier box can be slotted in on the day but pointed out the gear-set wouldn’t be matching and may develop a slight wine.
    Anybody know what year the change happened.
    May 2006
    Woolgoolga
    Its the input gear, it has teeth on the back of it for the pto chain. Can still get them no worries.
    Feb 2005
    Quote Originally Posted by Vern View Post
    Yep that’s it......
    Just wondering if a 2000 Defender would have a shaft with teeth??
    Oct 2012
    FNQ
    Yep that’s it......
    Just wondering if a 2000 Defender would have a fear with teeth??
    Have no fear Defender should have
    AM
    I think there was a change in the tooth count for pto at some point??
