Results 1 to 8 of 8
Thread: Joining multiple cables.
    St Helena,Melbourne
    4.28 MB
    I have the need to join 3 pairs of 6mm auto cable (4.59sqm), is there a compact junction box or terminal system for this situation ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2015
    Depends on the application and location a bit but I like this type: CABLE JOINERS TO SUIT 8B&S CABLE 8mm hole battery cable 12v wiring 4x4 E55-0380 | eBay
    Soldered with heatshrink over the top
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    St Helena,Melbourne
    4.28 MB
    What i need is more for a Y shape cable arrangement so joining 3 pairs of cable, for just 2 i would use a screw terminal strip but 2 x 6mm wont fit.
    Not sure if these will work as it says for solid conductors up to 4mmsq.
    3 Way Red WAGO PUSH WIRE Connector | Jaycar Electronics
    1974 VW Kombi bus
    Dec 2017
    wandin nth vic
    Connectors are all good but you cant beat soldering together. If your running 6mm i assume you are running reasonable current. Crimp and screw type connectors can invite corrosion and faulty joins . Tin your three cables separately, place 2 cables one side and the third onbthe other.then use one strand of wire and wrap it tightly around the three .then just heat the join , insulate. Done
    Avoca Beach
    Jaycar do a gold terminal block which takes 1x4 SWG input cable and up to 4 x8SWG terminals.
    You don't have to use the input just some of the outputs.
    Gold Power Distribution Block - 1 in 4 out | Jaycar Electronics
    I have had one for the past 5 years to distribute power around the back of the car.
    I reckon it is neat and gives expansion room.
    Regards Philip A
    St Helena,Melbourne
    4.28 MB
    Regards Philip A
    Perfect, thanks Philip. I did look thru the jaycar site but didn't come across them.
    1974 VW Kombi bus
    Jul 2014
    west of Transylvania
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by sierrafery View Post
    A bit overkill for my needs.
    I'd rather a mechanical joint in this size of cable as soldering is not easy with thick cable.
    1974 VW Kombi bus
