Thread: Brake master cylinder
    Sep 2012
    burrill lake NSW
    Oh Wise Ones,
    will it make me cry putting the larger master cylinder into a 1963 petrol 88" 2a that has a smaller one in it (CB style ). Have larger drums on the front and not moving enough fluid to brake properly.
    Looks as if the bolt holes won't line up?
    Thanking you in advance.
    Narre Warren South
    Fitting the LWB CB type shouldn't be a problem. I don't have a SWB one here to compare though.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    JDNSW's Avatar
    I'm afraid that it may make you cry - the bracket that holds the pedal, and is the bit the master cylinder bolts to, is a different part number for the 88 and 109 - and even worse, has a new pair of numbers after chassis number suffix 'E'. I'm not sure what the difference is, but hole spacing would make sense, seeing the M/Cs are different diameters.
    Narre Warren South
    So is it just a case of opening out the holes to match the LWB master cylinder ?
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sep 2012
    burrill lake NSW
    That's what I am hoping, was going open holes on cylinder if needed. Bit worried about the hole in the bracket for the cylinder to sit in, will find out over the weekend.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i have the larger unit in my series ii swb and the lwb 4cyl hubs etc and mine works fine.
    i dont recall having to do anything out of the ordinary to get it to work.
    it was easier to bleed as a bonus...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sep 2012
    burrill lake NSW
    As a follow up.. the larger master cylinder fitted with no modification needed. The holes in the bracket were elongated and fit both easily.
    The pedal now has a good feel to it, but she pulls up so slowly I might have to take an anchor with me.
