Results 1 to 10 of 15
Thread: Diff Lock vacuum actuator LT95 box.
    Mar 2012
    Cooroy
    Hello fellow RR tragic s,restoring my 1977 Classic in Tassie,trying to find a working actuator or
    someone who knows how to repair them
    Any ideas
    Thanks in advance
    Melbourne, Vic
    Quote Originally Posted by Hamersley View Post
    Any ideas
    Thanks in advance
    Centre diff lock in the lt95?
    You can make it mechanical. Make a lever with a bit of channel and attach the actuator arm
    Current: ‘16 Disco Sport (7seater) aka « Family Bus 2 »
    Sadly Gone: '77 RRC 2 Door aka "Beast"
    Gone: '92 RRC Vogue SE aka "The Family Bus"
    Long Gone: '99 Td5 Defender aka "The TANK!"
    Mar 2012
    Cooroy
    Quote Originally Posted by drover81 View Post
    Thank you drover81 darned good idea if I can’t get one easily
    Melbourne, Vic
    No worries - I can take a photo of mine when the sun comes up.
    There are a few threads floating about with people who have fitted 3rd party vacuum actuators. Seemed like too much faff for the value, but each to their own.
    Mar 2012
    Cooroy
    A pic would be much appreciated
    thank you
    Apr 2016
    Country Vic.
    Hello fellow RR tragic s,restoring my 1977 Classic in Tassie,trying to find a working actuator ....
    I'll have a peek in my (very) old box of bits I've had sitting for the past 20 years.
    I know I had one, still in the box too.
    I'll try to get to it tomorrow and reply back if it's still there(or been disposed of).
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Mar 2012
    Cooroy
    Quote Originally Posted by AK83 View Post
    Fingers crossed that would be fantastic if it’s still there .
    thank you Brian
    Apr 2016
    Country Vic.
    thank you Brian
    Unfortunately it wasn't.
    I vividly remember the box in came in, and why I replaced mine(not knowing exactly why it wouldn't worked).
    Mine originally wouldn't lift up, in my '79RRC. I got the replacement and removed the old one, replaced it with the new one.
    The only problem with the old one was that the flat guide that the lift switch slides on had been bent at 90° on the underside.
    Needed to remove it to see that.
    I straightened the guide slider thingie(made of copper or brass or something), and switch worked perfectly. ie. new switch wasn't needed!.
    Found lots of other RRC goodies in the storage box tho.
    Old and new thermostats, some weird electrical box with leads(can't remember what that was for tho), power steering reservoir filter, old original alternator, and an ICE(or possibly Ignition Developments) Bosch dizzy for a 3.5.
    But not the diff lock switch.
    sorry.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Melbourne, Vic
    thank you
    Here you go - lever is actually a threaded tube that's been bent accordingly.
    I noticed a couple of new MaxiDrive replacements at KLR last week.
