Results 1 to 10 of 11
Thread: Disco hights
    david7307 Guest
    Disco hights
    my disco 2 1999 is on 235/70/16 tyres i want to find out if my disco is on 2" lift or more ,so what would the standard height to roof level be if it was not lifted
    Apr 2016
    Country Vic.
    Quote Originally Posted by david7307 View Post
    I'm pretty sure it says on the bottom side of your sun visor.
    Something like 1940mm, but it also may give you the height with the roof rails(if fitted) and the sunroof(if fitted) too.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    david7307 Guest
    Thanks iam sitting at 1940mm but my disco seems higher, was told it was on 2" lift ,but distance from top of Tyre to wheel arch is quite large compared to other discos i have seen about the place
    Apr 2016
    Country Vic.
    Could be an illusion tho, eg. if the other discos are running larger tyres.
    eg. fit a 245/75, and it fills the wheel arches a bit more.
    D2s can run 265/75 (I think) without too much trouble.
    I find 235/70's are just a touch too small for a Disco.
    On my V8(D2) it came with 255/55/18's and I replaced them with 265/60/18's.
    So now it sits higher, but looks lowered due to the tyres filling the arches a bit more.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    The heights are in the rave manual.
    Sep 2012
    Adelaide Hills
    with lift kit an tyres, im 2.02m
    carparks suck.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Feb 2017
    Deception Bay, Qld
    My D2a has 235/70 on and shows 825 to 830mm at the wheel arch, my next set of tyres will be slightly larger to reduce the speedo error, that’s at about 4 kmh slow now.
    May 2015
    Williamstown, Victoria
    Quote Originally Posted by Eevo View Post
    carparks suck.
    My son, the 20 hour learner driver, tried to drive into a Macca's car park. Car par height is 1.8m. I had to reverse slowly back into the traffic.
    Ah we learn. I had to check the sun visor as well.
    Build date 11th Oct 2003
    LROCV #1410
    Mar 2007
    Warwick Qld
    With lift and roof rack on the D1, we're just under 2.1m
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Lift, tyres and rails have our D2 at 2.35mtrs
