Results 1 to 8 of 8
Thread: Ailing Td5
    Aug 2015
    Moe
    Ailing Td5
    Bog standard manual Td5 with a 10p engine with EGR intact.
    I've just had the head replaced with an AMC head due to cracking and fuel finding its way into the sump and now it seems like I have a wounded MAF.
    Nanocom airflow reading at idle is about 39 and at about 3,000rpm wide open throttle under load it's never more than about 300. This behaviour started immediately after the head was replaced. In fact I noticed as I drove out of the workshop forecourt.
    After a bit of testing with the MAF disconnected the "bum feel" is that it's a little smoother and has a little more "urge" but it's not a startling difference. Could be all in my imagination too. A generous blast or 10 of CRC MAF cleaner has made not a jot of difference to the readings or to the feel.
    Going back through my fuel logs it seems that over last few months consumption has risen from mid 9's l/100km to mid 10's. I had put that down to the cracked head putting the excess in the oil when it could've been the MAF in the process of karking it.
    I just wish that I had another MAF laying around so that I could test by substitution.
    Is the general consensus a dud MAF or should I be looking elsewhere?
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Apr 2015
    Bondi Junction
    Likely dud MAF, post where you are cause someone may be happy to lend you yours for a few minutes to test.
    And buy genuine if you need to replace, do not waste the money on the knock offs, ask me how I know
    Sep 2009
    Sounds like a dud MAF to me. 60 at idle is normal.
    Feb 2013
    Queensland
    Sounds like the maf buy genuine I just replaced I got mine of ebay from roverlord it was genuine and arrived quickly great service .
    Aug 2015
    Moe
    Thanks all. Looks like a new MAF is in order.
    Seems a bit of a coincidence that the car was running perfectly apart from steadily rising oil levels and when I got it back from its head replacement the MAF has magically gone bad.
    Oh well such is life with a Land Rover...
    Mark F...
    Vk3KW
    http://jandmf.com
    Jan 2014
    Perth Western Australia
    Quote Originally Posted by Markf View Post
    yep...that pretty well sums up a land Rover, if you believe its something more sinister then find another mechanic.... keep looking for one until you find one you trust.
    Daz
    Aug 2015
    Moe
    Quote Originally Posted by DazzaTD5 View Post
    Naah I trust VSL - they're pretty good.
    It's just life with a Land Rover. My old classic RR was a conspiracy theorists delight. That car would've made a hardened conspiracy theorist out of a committed sceptic...
    Mark F...
    Vk3KW
    http://jandmf.com
    Aug 2015
    Moe
    New MAF - thanks HEAPS to Harro. Runs a LOT better especially at low revs (<2k RPM).
    Funnily the easily caused EGR valve stuck shut faults can't be induced now. Used to happen every time with wide open throttle under load at over 3k RPM.
    I wish I understood more about how the ECU (10p engine with NNN ECU) uses the data from the MAF. More reading of RAVE and the Nanocom doco is in order.
    Mark F...
    Vk3KW
    http://jandmf.com
